Can anybody ID this head ?
I got this in a package deal last summer . There were alot of lotus and fiat parts but this head has me thinking. It has no #`s at all not even a logo. The cams look like they took some serious regrounding too. Anybody ? I know its not a alfa spider head cause I have a spider at the shop now and its different.
Kurt Williams http://forums.pelicanparts.com/uploads/parts(11).JPG img]http://forums.pelicanparts.com/uploads/parts (15).JPG[/img]
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd Last edited by pjv911; 04-20-2003 at 01:02 PM.. |
Pictures didnt work. Will try later
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Kurt,
The spaces are the problem. This might work: Pic... Which makes the first url look like this: http://forums.pelicanparts.com/uploads/parts%20(11).JPG Don't know how to fix the img tags. Chris. Last edited by ChrisL; 04-20-2003 at 12:59 PM.. |
Here goes another try.
in the image name on your harddrive, change it to get rid of spaces and parentheses. Then upload.
OK gotta get back to the family. My wife keeps calling. HOLIDAYS !
O.K one more try. I renamed the files.
Senior Member
Is that a head for a Offy? Any other markings or names? How about some more pictures.
Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
No markings at all . Strange
Senior Member
Take a look here:
http://www.milleroffy.com/miller_fwd_255_engine_carb_side_web.jpg http://www.milleroffy.com/miller_fwd_255_engine_front_quarter_web.jpg http://www.replicaengines.com/products/offenhauser.htm It looks close... are the threads on the head metric or SAE? Joe
Anyone else ?
Just a hunch, but it looks like it could be an Abarth cylinder head.
I seem to remember seeing a picture of an Abarth engine at some point in time that had two webers mounted between the cams. The small "lip" on the side away from the exhaust ports should be for the distributor. One thing that sort of points toward an Italian design is the style of cam retainers. They look very much like the camshaft retainers on an Alfa Romeo cylinder head. Good Luck! Fred Cook '80 911SC coupe |
Can you give us an idea of scale? Dia of valves and comb chamber would be good. As would thread pitch, metric SAE or Brit Std?
Coventry perhaps? i agree with the cam holders, but it doesn't have an Italian flair to it. More like utilitarian.
Stuart Williams '65 911 2.0 '68 FIAT 850 Special '71 GT6 ex-Zundapp collector |
Senior Member
Believe I found the motor. Its an Abarth...
http://www.europeancarweb.com/features/0209ec_twincam/ Very bottom set of photos in the center. Shows the motor with the carbs, intake and tach drive output on the LH cam cover. Joe A
Your the man Joe ! Now what do I do with this head ? I wonder if its worth anything ? Probably not . Do you think it was used in a Fiat ?
Senior Member
I would inspect it to make sure that its in good shape and no cracks etc then advertise it to the historic racing crowd. Bet its worth a lot more than you think if its in good shape. Abarth parts were not made in large numbers for the most part and this one could be rare...
Good luck! Joe
Here`s the car it was offered in. Looks pretty cool .
Ill try again. Heres the car it belongs in.
The picture wont load but here`s the link anyway. http://www.maranello.cc/ALL.Ferraris/laguna-seca---paddock/fiat-abarth.html
i like this sort of slightly OT stuff!!
good detective work! i'll attach the engine pic to save others the trouble. max
max |
