1982 sc distributor question
Hello,
I am in the process of disassembling my distributor - 0 237 304 016 for cleaning. I have measured the axial movement at .028, which I believe is in excess of specs.
I have read that originally there was a fiber washer somewhere that usually disintegrated, resulting in addition axial movement.
My question is where was the fiber washer originally located? I need to know so that when I replace it with a brass one now sold by Partsclassic as a replacement, where it goes. In addition, I would like to know any other tips regarding reducing the axial movement to spec - I have looked everywhere and have found numerous distributor parts diagrams but none showing the shim washers. There is zero lateral movement so I am not going to address the 2 brass bushings. Thanks in advance for your help.
Dave
Old 09-28-2020, 10:27 AM
Under the radar
Trackrash's Avatar
This may help. Thanks to Draco.
Distributor Tune Up - Repair
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-28-2020, 11:10 AM
Great info, thanks!
Old 09-28-2020, 12:26 PM
I previously posted this in 83 sc distributor and should help you out. When I rebuilt my 87 Carrera distributor the fiber washer was on top and metal beneath.
Originally Posted by HaroldMHedge View Post
TSB 78-04 lists an axial limit of 0.2 +/- 0.1 mm.
TSB 78-04
The Distributor Repair Kit, 1-237-010-007-INT, has the shims that are needed to rebuild a distributor but you need two of them to get two fiber (phelonic) washers.
83 SC Ignition Distributor Bushing Replacement has a good procedure on rebuilding the distributor.
It appears that Pelican no longer has the Bosch rebuild kit 1-237-010-007. VW Distributor Repair Kit 12118630239
Last edited by HaroldMHedge; 09-28-2020 at 12:53 PM.. Reason: 1-237-010-007 NLA in Link
Old 09-28-2020, 12:40 PM
