-   -   Smog Problems (http://forums.pelicanparts.com/porsche-911-technical-forum/1074347-smog-problems.html)
Antonetti 09-28-2020 04:36 PM
Smog Problems
Good Day, my 1985 Carrera has failed California Smog testing 3 times recently. I’ve had a smoke test done and no leaks were discovered. I’ve run a fuel additive through one complete tank of gas and the most recent Smog Test failure showed very high NOx readings. It seems that I may have to replace the Catalytic Converter and/or Oxygen Sensor. Any advice or solutions. Frustrated.
yelcab1 09-28-2020 05:59 PM
Post your full results ....
Cals911 09-28-2020 07:39 PM
Failed evap also?
Nick Triesch 09-28-2020 10:19 PM
Motor must be very hot when you take it in. Also I put 45 pounds of air in the rear tires for less drag while it’s rolling. Change oil. Make sure car is tuned up. Again, real hot motor .
Targa Me 09-29-2020 11:15 AM
I believe a high NOx reading indicates running Lean. Could be a vacuum leak.
How many miles on this engine?
Can we see the smog check results?
eastbay 09-29-2020 02:35 PM
High NOx on a car with no EGR system is a bad CAT
bigred23 09-30-2020 01:07 PM
Agree; I have an unused CARB-certified cat that I could sell at a discount...
