What Power Increase from Compression Ratio?
I was looking at replacement pistons and was wondering....
All things being the same, what would be the effect from an increase in the compression ratio for a 2.7L RS Spec engine? Can anyone guestimate the following? 2.7RS w/ 8.5 comp ratio = 210 hp 2.7RS w/ 9.0 comp ratio = ?? 2.7RS w/ 9.5 comp ratio = ?? 2.7RS w/ 10.0 comp ratio = ?? 2.7RS w/ 10.5 comp ratio = ?? 2.7RS w/ 11.0 comp ratio = ?? Regards, Andrew M |
equation for engine efficiency is 1-(1/CR)^0.4
for 8.5:1 you get 57.5% for 11:1 you get 61.7% a net gain of 7.3% or 225Hp @ 11:1 |
| All times are GMT -8. The time now is 04:07 PM. |
