911 brake pads
Am I the only one slightly confused when trying to purchase brake pads for my 1975 911.
38 choices??
Old 09-27-2020, 12:04 PM
Flojo's Avatar
about every brake manufacturer offer pads for the early 911, may it be M or A calipers.
make your choice.
mostly same brand for disk and pad work well together if you don't want to go the long way testing (fooling) around for combos.
ATE in general is no brainer.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 09-28-2020, 02:45 AM
Was ATE an original supplier? Agreed to match disc and pad manufacturer. Our 1975 911S will only be on the street, but I have always liked good brakes.
thanks
Old 09-29-2020, 05:01 PM
HarryD's Avatar
The Factory put Textar or Jurid on the cars from the factory. Good everyday pad.
Lots of more aggressive choices out there if you need them. What is your driving style?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-29-2020, 05:26 PM
7783911's Avatar
i have a 77 targa but its had extensive work by PO...i am assuming oem calipers...whats the best way to know which you have?
Old 09-30-2020, 04:55 AM
HarryD's Avatar
Post a picture. I may be all we need.
Harry
2020 MB E350 4Matic
Old 09-30-2020, 04:17 PM
Our '75 911S will be used for spirited street use only. She is a low mileage rust free example with a rebuilt 3.0. My inclination is to go with stock and replace calipers/rotors/pads for as close to a factory performance.
Old 09-30-2020, 06:37 PM
HarryD's Avatar
Good plan. If you find the brakes unsatisfactory, you can always easily upgrade your Pads. I recommend thyme you flush your brake fluid annually as well.
Harry
2020 MB E350 4Matic
Old 09-30-2020, 06:47 PM
7783911's Avatar
77 targa brake caliper type?
heres a picture of the rear caliper, (need to pull wheel on front to get that photo)
Old 09-30-2020, 07:16 PM
HarryD's Avatar
While not expert, sure looks like a Stock Steel ATE Caliper. Is it magnetic? The car came with M Steel Calipers and Aluminum S Calipers.
Harry
2020 MB E350 4Matic
Old 09-30-2020, 08:51 PM
7783911's Avatar
Thanks Harry, i am assuming they are stock but am confused by the designations of A versus M types and if that influences the choice of brake pads i need to order?
Old 10-01-2020, 04:21 AM
Registered Minimalist
75 911s's Avatar
I think the 74 S came with the aluminum S calipers, but the US 75 S came with steel A calipers in front on 3" centers. The Aluminum S calipers are 3.5" centers. I'm not sure what the Carrera came with.
Here are mine after the fresh PMB treatment.
Also I think the MY75 was split for brakes. The first half of MY75 being a different front caliper like the 74 (but not the S).
There were also two strut/spindle options and 3 shock options. Koni (red with 3.5 centers brake caliper spindle), Boge (black with 3" spacing) and Bilstein (green with 3.5" spacing)
They were all steel front and rear calipers to my knowledge in 75, I think even on the US Carrera which was primarily a stickers/flares/tires upgrade.
going off memory here, but if you check the Redbook, it should cover in detail.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 10-01-2020, 04:52 AM
7783911's Avatar
redbook? dont know that one, i checked my bentley and no indications as to a/m
looking at calipers (hard to see any identifying numbers)
front has #281
Rear seems to be p68
Old 10-01-2020, 08:09 AM
7783911's Avatar
front could be 287?
Old 10-01-2020, 08:30 AM
7783911's Avatar
its for a 77s targa
Old 10-01-2020, 08:31 AM
7783911's Avatar
i ve determined that I have a fronts and m back calipers. what is the suggested pads for them for street use?
Old 10-01-2020, 09:57 AM
HarryD's Avatar
An idea. Pull the pads and see if you Can find a manufacturer name and model number. Use that to cross reference.
Harry
2020 MB E350 4Matic
Old 10-01-2020, 09:58 AM
HarryD's Avatar
Stock. Jurid or Textar would be my choices.
Harry
2020 MB E350 4Matic
Old 10-01-2020, 12:05 PM
