markmalin's Avatar
3.2 Carrera US headlight trim loose. Fix?
Hi all
One of the headlight trim rings, the color-coded outer ring, on my 85 Carrera is screwed in at the bottom, but the top lip won't stay on so it flaps forward. I see the rubber gasket (ring) between the fender and headlight trim is separated...I'm hoping a new ring will help -- but is this a common issue? Any fix? It seems like the top lip on the inside of the ring won't engage on the fender's window opening lip once I tighten down the screw on the bottom.
Thanks for any thoughts
Mark
Mark - New Glarus, WI
Old 10-01-2020, 01:19 PM
Still here
pmax's Avatar
Ah, another marvel of Stuttgart's minimalist engineering ...
Headlight seal
Old 10-01-2020, 02:02 PM
markmalin's Avatar
Headlight seal
Thanks.
Man...I think the lip on the top of my fender isn't as big as in some of those pictures. Maybe the P.O. messed it up. Could also be that mine has a "clip-on captive nut" on the screw hole on the bottom - looks like the original soldered on nut is long gone.
Old 10-01-2020, 02:30 PM
1988 3.2 This is a major pain, I would like to clean one of my reflectors but I won't remove the ring because it always takes ages to get it to latch and get that stupid screw in there. Some one should take pity on us and fabricate some gaskets with a slightly smaller diameter.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 10-01-2020, 04:58 PM
kevbo's Avatar
Thanks I feel better. I fought this battle last weekend.
Kevin
1986 Carrera Targa
Old 10-01-2020, 06:34 PM
