93060611701 vs 93060611703
Hi to all, I'm starting up a 1983 911SC that was on storage for the past 19 years.
![]() Because of bad fuel I’m replacing everything from the tank to the injectors (air, fuel and fire) because of gum and rust. Since I already dropped the engine I decided to change the temp and pressure switches, but I can’t find the 35oC temperature switch since is no longer available. After 19 years stored, I want to assume is bad or could fail. ![]() I came across a review from a 83 Targa owner stating he successfully used a different switch, which is available at my local auto parts store. ![]() ![]() My question is: Will switch number 93060611703 work the same as switch number 93060611701? |
