New Product: Deltamax Ignition Control Unit
Hi Guys
This product has begun to turn up in a few Aussie magazines etc... http://www.delta-digital.com.au/ Go to Deltamax prompt Have a look and tell me if you think this could be a viable alternative to MSD et al It is certainly cheap enough at $300 Australian ($180 USD). Cheers |
Not much info on the website :( Sounds interesting though.
Bump
Looks like it mights control the advance curve. Could be pretty cool. Depends on the sensors it takes, I suspect.
It looks cool....but not much info. Seems like you plot the cuve with a PC. That's good! But I wonder how finite the increments are? And the price, at todays exchange rate is sweeeet! Less than an MSD 6. $330 Aus+$200+ US.
Does it also do the job of a coil? Or is that required? As a guy with an older 911, I would be a prime customer. Would I lock my dist to eliminate the curve? Will it take the output of a Crane optical sensor? And I'll need a pretty long download cable, as I have no laptop! |
Based on size, I'd be pretty suprised if it did the capacitive discharge aspect of the CDI.
It would be extra cool if there was a way of adjusting the advance at different load points (even just thottle position). |
Jake, you're thinking like me. I currently run a Crane XR700 and coil, but the idea of being able to map out my entire rev range is appealing. I locked my advance some time ago and simply run 36 degrees total. I like the idea of dual mapping for *****ty fuel, but with the flick of a switch I can run something else. As Cam points out, I get the impression that you supply the coil.
I'm not ready to buy at the moment which is why I'm not sending off emails to the company. I just posted it 'cause it might suit some older car owners on the board. |
Has anyone tried this yet?
| All times are GMT -8. The time now is 01:01 AM. |
