Acceptable voltage range 3.2
Hi all,
I spent the weekend ripping around in my '85 Carrera and have a few questions for the more experienced owners on here. On a few occasions, when I blipped the throttle to downshift, I heard a loud shriek from one of the belts. It does not occur EACH time I rev-match, and I cannot replicate it when the car is actually in gear. I picked up this voltage meter/battery monitor a while back and popped it in as an afterthought as I was on my way back through town. The reading would swing as I applied or backed off the throttle but I'm worried about acceptable readings? At times the meter read as high as 18v and other times it dropped below 12v. Is it dangerous to have the voltage spike so high? The fan belt doens't look worn or frayed, and there isn't a worrying amount of slack, but it seems likely that these two things are related. I have the original tool roll including the fan pulley holder tool. It would also be helpful to understand what range is considered "safe" for the electrical system. Thanks in advance. |
How long was it at 18V? I've seen mine touch 15 before, but it's nearly always around 14. Does your battery show any damage such as leaking acid? Keep a good eye on things.... you may need a new voltage regulator.
I'd check volts at the battery using a multimeter as those cigar lighter units can be a bit wonky. |
18 volts is (imo) too high to drive until fixed -- check under/around battery for evidence of boiling over and have alternator/voltage regulator rebuilt -- should be an old-school shop in/around Portlandia
you could confirm it's not the gauge by testing it in another (newer) car |
I wouldn't feel comfortable with the car voltage spiking to 18 v either. Spikes are better than sustained and/or frequently elevated voltage. But I 'd always be worried that I could fry something.
Voltage regulator
Looks like a voltage regelator issue.
Have the the VR tested under load. Should be around 14.2V Best, Gerry |
Stop, do not start or drive, there are sensitive capacitors in different components and they are rated at 16v. At 18v stuff starts to sizzle along with the battery. Replace/rebuild the alternator. Stat!
From what I understand, best course of action for the alternator is to remove it and bring it to a shop that specializes in alternator repair/rebuilds. It would be great to find someone who's worked on Porsche units previously but the consensus seems to be it's not a must-have. I'd be grateful for recommendations in the Portland/Vancouver WA area if anyone has recent experience. Quote:
I believe that most if not all 3.2s came with an alternator and internal voltage regulator.
Get yourself voltage regulator..once you are at it have a look at the rotor where the brushes ride..If still ok just replace it and you`ll be ok
or take a picture of the rotor and show it to us here... Ivan |
I replaced my alt with a modern alternator from Classic Retrofits: https://www.classicretrofit.com/collections/upgraded-alternators I also added a Clewett pulley system: http://forums.pelicanparts.com/porsche-911-technical-forum/1031002-clewett-alternator-crank-pulleys.html The 911 series alternator is the same basic design from the 60-70s. The Classic Retrofit brings a modern design to the table, check out the sites/threads. Having a modern alternator and pulley system brings my 911 solidly into the 1990s. Was it cheap, nope, but when compared to the high amp alternators for race trucks and sports cars, the price was in line with low production volume custom parts, same with the pulley system, its a beautiful piece of CNC machine work and is worthy of being buried on the back of a 911. BTW my alternator runs amazingly consistent 13.9-14.1 temperature dependent. Check the voltage at an RPM above idle, say 1500 RPM. The Classic Retrofit puts out a whopping 175a at rated RPM, while my amp schedule will never get anywhere near that, having a system the for all intents and purposes is constantly "idling" along at any possible load. |
Must mean 13.9 - 14.1....
I've been though this with several 80's 911s. Don't bother with just the voltage regulator, replace or have a quality rebuild of the alternator ASAP. As mentioned above, many components are at risk. I've ruined batteries, clocks and a tach due to voltage spikes.
The high voltage reading on my 1980 SC is about 13.8 volts. With the engine/ignition off, the battery reads 12.5 volts. I get essentially the same numbers on my 1994 Jaguar XJS so they appear to be in the realm of normal! The high voltage reading on my 2014 Ford F150 is usually 14.2 volts.
I am always looking at my voltage. 14.2-13.9 normally with nothing on. I had it go to 15.1 once and my radio was tripping out. Turned out to be some old grounds. Check door light contacts. Also check off your battery too.
Mine is between 13.8-14.2.
1986 Coupe here...Going through all things electrical and here is where I am:
Battery Cold: 12.7 Car started at idle: 14.1 - 14.0 Car at 2000 rpm: 14.3 Car at 2000 rpm w/lights: 13.9 Just took the car out for an hour and voltmeter in dash read 14.0 pretty much steady with lights on. With the lights off meter read 14.3 while driving. This car has over 200,000 miles on it and comes from a humid background (if that matters). 14 and above seems high to me...just not finding a definitive answer. I have no issue with pulling the alternator and rebuilding - it is very old and very used. Hopefully resurrecting a thread from 2020 isn't too taboo here :) Thanks! Erik |
I don’t remember the factory spec, but 14 doesn’t seem outrageous. The risk would be any spikes as the electronics in these cars are old and not very robust. If concerned, I would check your grounds and have a quality rebuild done on the alternator… or replacement, but I think that is big bucks now.
After all grounds changed and new VR, 13.8-14.5 nothing on. Above 2000, 14.3-4 for the most part. Only counts over 2000rpm. Load up the fogs and ac at night and idle is 11.9-12.0 until 2000. Book says same.
I have the same readings: 14.0 without load in idle. 13.7 - 13.9 with load om my 1985. Quite steady during a drive (I have a permanent battery monitor).
As long as it stays below 14.5V I am not worried. Sent from my iPad using Tapatalk |
I've had a digital meter in the cigarette lighter port. Nice little unit that typically shows 13.6ish on startup / idle, then as the car warms up it'll go to 13.8. Even on boost I've not seen it higher.
Being fond of the analogue dials (an age thing), I've wired in a voltmeter. An AFR guage as well, which I've had on the shelf for a couple of years and finally got around to installing this week. http://forums.pelicanparts.com/uploa...1673181877.jpg |
Just got back from an hour long drive down here in the Hill Country. Battery was full this morning and on the highway with lights on was 14.2 very consistent and without lights was 14.4 again consistent. Checked with two plug in digital monitors. Both read same.
I have a spare alternator from my other 911 (written off) that had 65,000 miles on it and am thinking about swapping with this car (with 200,000 miles). 14.4 with no load just seems high...seems we all vary in our findings. I know if I swap out the readings will be the same...isn't that how it always goes??? Great replies...glad I found this thread. Erik |
I am looking at the Bosch analogue dial...nicely done. Erik |
13.5V-14.5V is the standard range for a lead-acid battery system in all cars. Below that won't hurt anything, but may not recharge your battery quickly or fully. Above that you start to have problems with shortened battery life. Way above that you can fry electronics. right around 14V is as good as you can get.
Your fine at 14.4. I’d leave it. It took me 1/2 a year to get 14.4 constant. That’s with all new grounds and every bit electrical shiny. I wrote a post on it. Search my name. |
Have you checked the voltage with a Multi Meter?
Had the same issue, replaced the voltage regulator but it's only a band aid. The car has the original alternator and the slip rings have some life in them but are grooved and I'm anticipating only about 5k before Ill have to get new.
Yes...I did and numbers were the same. Very long story short I have a spare alternator (written off car from an accident with only 65,000 miles on the engine) and I might swap and have this one with 200,000 miles on it rebuilt. Took out this alternator and the ground wire/cable was pretty worn out. Other major grounds have been replaced. If everything comes back producing the same outcomes then at least I know, record wise, where I stand. Had some surging problems and a bad battery...suppose I am a bit over-worried now. |
Have a new VR in my shopping cart here at Pelican...feel the same with 200,000 miles on this... "band aid". Probably time to rebuild. |
Food for thought - get a new (not rebuilt) 90Amp Valeo alternator from Rock Auto for $330:
https://www.********.com/en/moreinfo.php?pk=9550352&cc=1262764&pt=2412&jsn=839 The asterisks should say "rock auto", all one word. The Bird doesn't allow outside URLs or apparently competitor names, period. No core charge, either, so you can keep your old one and get it rebuilt or whatever. |
Well, bit the bullet and bought a new alternator (Valeo) and rechecked all grounds.
Installed and took out for a drive - am still at a constant 14.4 with nothing on and 14.2 with headlights on. Very very stable. Idle is 14.4 in traffic and stable. I will say my lights are incredibly brighter and now I see my shift light is the orange it's supposed to be. :) I have been back and fourth on buying new and when I pulled the one on the car it was a Bosch/Rebuilt. So, my readings are pretty much the same although dead stable now and I guess I will live with 14.4 running and 14.2 with all accessories turned on/activated (headlights, heater...took out the A/C). |
| All times are GMT -8. The time now is 08:21 PM. |
