Replacement battery
What battery is recommended for my 1982 911T?
The Interstate MTP-91 needs to be replaced and is no longer available.
It's hooked up to a trickle charger since it's driven infrequently.
Old 10-04-2020, 04:41 PM
Retired, finally
SiberianDVM's Avatar
Interstate still lists a MT-91/T6. Practically every battery supplier carries a Group 91
https://www.interstatebatteries.com/products/mt-91/t6?productLine=auto&subcategoryKey=&ignorecategoryid=true
Did you mean a 1972 911T?
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 10-04-2020, 05:46 PM
Diss Member
Quicksilver's Avatar
Wonder if he meant he has a 1982 911SC Targa. Or a 1972 911T...
Either way I wouldn't put another conventional lead acid battery in the car if simply for the reason to avoid corrosion in the battery tray. An Odyssey 925 AGM is too easy of a choice.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-05-2020, 05:53 AM
Retired, finally
Yeah, I run the PC925 in my '77, but relocated to the smugglers box with a Rennline mount. Frees up space for the pump, toolkit, and a trickle charger.
Old 10-05-2020, 06:24 AM
