oil change drain plug torqe specs
what are he torque specs for respective drain plugs when changing the oil?
with is a good weight synthetic oil for fall in the Northeast?
thanks
Old 10-06-2020, 08:29 AM
Wayne's book says 30 ft*lb.
Are you driving the car in the Winter? I leave 20w50 Penn Grade in the car but don't drive it once the roads get salty/sandy.
Old 10-06-2020, 08:33 AM
I use M1 15W-50 year round in my high altitude southwest climate.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 10-06-2020, 08:42 AM
I tighten the drain plugs to one 'unh' and use 20W50 down to about 30-35F, below which I don't drive the car.
'80 SC Targa
Avondale, Chicago, IL
Old 10-06-2020, 09:23 AM
Winter driving.. not much
I like driving in winter ONLY if it’s dry.. but not very often... you like 20/50 all year round? Synthetic?
Old 10-06-2020, 01:46 PM
just responded to your other post on this topic -- Synthetic oil change for the northeast
be sure to replace the crush washers on both drain bolts whenever you change your oil and make sure you have a drain pan that can hold/contain the 2 gallons of oil that will flow out of the oil tank when you pull its drain plug.
Old 10-06-2020, 02:18 PM
Tags
oil , torque specs
