Help me diagnose my gearbox whine.
I just did my 1st drive after installing a SBH 930 gearbox in my car, The previous owner of the 930 box has taken the LSD unit out of it and put in an open diff. instead, so I knew that I might need to set the backlash on it, so I did a pattern check before I install it in the car :
![]() ![]() I took the chance and installed it as it is, it turned out I pushed my luck too far, as I can hear a whine when ever I exceed about 30 mph, and it clearly a R&P noise as it would still be there even if I press the clutch. I can drop the engine at anytime with no issues, but I need to figure out how to approach setting up the R&P correctly, I have done more than a dozen muscle cars rear ends with ease, but I never did a Porsche!, I can't even think how do I suppose to check the backlash with the whole diff assembly hiding inside the housing. Please let me know if you have any tips/tricks, thanks!
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
You need to set both the diff carrier bearing preload as well as backlash (freeplay). Can't be done with the marking fluid in your pictures. The workshop manual describes the process and tools needed.
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
Are the bearing preload and the backlash can be done by using different shims on the carrier? If so, I think it can be set while the trans still in the car, right? |
Recommend removing the transmission and making adjustments on a motor stand. If the pinion gear hasn’t been changed should only require shimming the diff.
75 930, 76 930, 83 SC EFI turbo |
Where do I find the shims/bearings and the s[special tools to make the measuring/adjustments for it? I have searched the whole Pelican parts with no luck.
gearhead
A 385 tool is a rare beast these days. I paid several thousand for mine.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Red Line Service
I'd still like to find one Matt. I borrow P.Z.'s when I need one.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
You might be able to do a basic preload check in the car, but to check the bearing drag the pinion must be removed. And any adjustment to the preload will probably alter the backlash. The whole process cannot be done properly with the transmission in the car.
Jon B. Vista, CA |
You can check the bearing drag by removing the ring gear, much easier in this case.
If you remove the ring gear, you would then need to clean the gear and the diff housing, re-mount the ring gear, re-torque the 12 bolts and install and peen 6 new lock plates. If the guide fork plate is removed from the transmission, it might be possible to lock 3rd or 4th gear and in effect lock the pinion shaft. Possibly with an improvised tool bolted to the case. It would require a complicated work-around from the normal process, and the results may be questionable. The best and most accurate way to do all this is out of the car, properly, with the parts cleaned and dry except for some oil on the bearings.
Jon B. Vista, CA |
