1979 911 SC
Just dented my sump plate - big deal or no?
Sorry if it's a stupid question but.. I just went to do my first oil change and I must have placed the jack poorly. I've jacked it up plenty of times from this point before but must have gotten lazy. I'll order a new one but is this something I should be concerned about?
Old 01-09-2021, 10:41 AM
proporsche's Avatar
don`t worry about it...unless you do not like the esthetics;-)))
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 01-09-2021, 11:05 AM
If doing an oil change right now. Take it off flatten out the plate and reinstall it.
Old 01-09-2021, 11:40 AM
Let me chime in....
I used to subscribe to the technique of using a phone book as padding lift my SC rear up at the engine case. NEVER AGAIN!!! but why ??
Because I did it once too many a time - and I disturbed the sacred engine case O rings that connect the two halfs of the case - resulting in a fatal oil leak.. the fix was complete engine disassembly replacement of the o rings - re-assembly of the engine - cost of my mistake was ~$9,300 .
when you think of it - lifting the entire rear end - and the center of that lift point is a seam - and ANY violation of that seam and the internal o-rings = disaster... your call...
I only lift at the designated jack points now > yeah I wish the older 911s had a center lift point - but it is what it is...
kgl
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 01-09-2021, 11:53 AM
Reiver
Reiver's Avatar
Originally Posted by kimlangley7 View Post
Let me chime in....
kgl
I agree.... I know everyone that does this refers to the old Porsche photo of this being done.
What did the car in that picture weigh? What does your weigh? That was a new Porsche....how old is your block?
De Oppresso Liber
Strength and Honor 5th Legion
Old 01-09-2021, 12:01 PM
1979 911 SC
Those are both really good points. I'm inclined to agree with you after today. I would be really interested in knowing the other safe jacking points on this car. The front is just as challenging. Where do you place the pads when your putting this car on a lift without damaging that little weld seam?
Old 01-09-2021, 01:09 PM
Still here
pmax's Avatar
I don’t use the sump as a jack point but the last pro did.
So perhaps he knows the proper technique.
Old 01-09-2021, 01:19 PM
While many folks, published and learned owners alike, suggest lifting the rear end using the engine, I don't recommend it. The engine wasn't designed as a vehicle structural element and no amount of padding negates about 1500 lbs. of force concentrated at the lift location. There are other methods to raise the rear end that don't stress the engine crankcase.
BTW, the only sealant between the crankcase halves is a thin film of Loctite 574 or equivalent. As in all things, YMMV.
Sherwood
Old 01-09-2021, 01:24 PM
proporsche's Avatar
somewhere i did see Ferry Porsche in the garage lifting 911 on the engine but i cannot find the picture;-)
Ivan
Old 01-09-2021, 01:32 PM
sugarwood's Avatar
See pictures #3 then #2
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/01-Jacking_Up/01-Jacking_Up.htm
1986 Bosch Icon Wipers coupe.
Old 01-09-2021, 01:40 PM
Reiver
Reiver's Avatar
Ivan
That is the pic I was referring too....what did that early 911 weigh? What does the average SC/Carrera weigh? How many hundreds more pounds?
How old was the block in that just made car...how old is your block?
What does an engine rebuild/re seal cost?
Won't even mention magnesium cases that always need a line bore on rebuilding....the first time I saw that recommended I laughed....and what is Ferry saying in that picture..."Dummkopf, use the lift points"
De Oppresso Liber
Old 01-09-2021, 01:50 PM
proporsche's Avatar
really he said that? i would love to see it ...;-)
Ivan
Old 01-09-2021, 01:59 PM
and Ferry could get a new engine for free whenever he wants. use ramps and most of the time you wont even need to jack it. if you do then jack it on the suspension arms at the shocks.
Old 01-09-2021, 02:07 PM
2 4x4s and a 2x8 on top work great i have 4
Old 01-09-2021, 02:10 PM
Here's the pic of Ferry Porsche and a 911 lifted by a very German floor jack. This photo was used in the Pelican Parts tech article and by others to illustrate lifting the rear end (Sugarman):
For many people, this confirmed the engine is a recommended lift location, or does it?
Old 01-09-2021, 11:39 PM
proporsche's Avatar
where exactly is this jack placed??on the pic..?
well i have asked but i kinda know..this is a jack to remove the transmission with the engine together...
Old 01-10-2021, 01:11 AM
It's a 914 ...
stownsen914's Avatar
I'll confess to having jacked by the sump plate, but I'm more comfortable jacking from the front edge of the case where it at least has some vertical support. May not be possible on all models.
Old 01-10-2021, 03:41 AM
walt's Avatar
Ferry Porsche pointing out the fact that with someone lying underneath the car maybe we should use jack stands.
Walt
82SC 3.0
81SC 3.6
Old 01-10-2021, 05:40 AM
proporsche's Avatar
As far as i remember we had in the 1980`s, Porsche factory floor jack at the shop-similar to the pic above. It had a flat plate with side brackets..it was placed right under the engine-those side bracket served for balancing the engine while it was out.It was was a perfect snug fit right under the sum plate and one for removing engine and trans. together .Also later plate with cut outs for the Carrera case to fit.
I wonder if any the older boys remember that one?
Ivan
Old 01-10-2021, 05:47 AM
Navin Johnson
TimT's Avatar
Looks like where the engine and transmission meet..
I use hockey pucks between the jack and whatever surface I'm jacking against.. have a half dozen where I keep my jacks stored
'69 911 GT-5
'75 914 GT-3
and others
Old 01-10-2021, 05:54 AM
