Pilot Bearing - 993 Crank - 3.0 flywheel
We are using a 993 crank with a 3.0 late flywheel..
On the orignal 3.0 crank where this flywheel came from, the pilot bearing bolts to the crank with 3 small bolts. But the 993 crank doesnt have the 3 small holes. Is there a pilot bearing that fits the SC flywheel to allow the use of the 993 crank? |
You can tig a few spot welds around the bearing flange to the flywheel. Don't need no stinkin' bolts.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 10-13-2020 at 10:08 PM.. Reason: Sp |
I don't resurface flywheels anymore, just replace it. Too many past issues.
Just trying to give an idea to get the job done.
I'm probably making too big a deal out of this, but my welding skills are seriously rubbish and didnt want to ruin a flywheel. Found this on the petrick site.. https://patrickmotorsports.com/products/flw-930-102-042-pms And similar right here on pelican https://www.pelicanparts.com/More_Info/99905216900M296.htm?pn=999-052-169-00-M296&bt=Y&fs=0&SVSVSI=873 Guess I'm just trying to establish if these are a 'press fit' into the later flywheel.. |
Looks like it. Didn't know they existed.
