What is this hole for?
Ok. First question for the team here:
Take a look at the photo. I dont think that hole belongs there, but its clear that it was there from the factory. In case its not clear, the area is in the windshield path looking from the drivers inside out. I should weld that hole shut, right? There is no drain path below. Let me know what you think... Thanks. Steve ![]() My Build Thread: https://forums.pelicanparts.com/porsche-911-technical-forum/1182923-follow-along-my-1979-911sc-build-adventure.html Last edited by AcidGypsy; 10-07-2025 at 01:04 PM.. |
I think that's the hole for a heated windshield wire.
Tru6 Restoration & Design |
Good point -factory propably make them on both sides...since thsi one is LHD 911
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks Shaun! |
