jaydubya's Avatar
How to remove lower dash trim (knee pad)?
Have the car interior completely strippped out now for a roll cage install but I can't figure out whether or not the lower part of the dash can be separated from the main part or not. If so, how is it attached? I'd like to remove it so that the knee bar for my new roll cage can be fitted closer to the dash.
See the section highlighted with a yellow line in the image below.
Car is an 82 911SC.
Thanks,
Jeff
'82 911SC racecar
'05 WRX STi
Old 02-06-2007, 08:53 AM
ttweed's Avatar
The kneepad is attached with integral studs that are bolted through the lower dash sheetmetal. Feel the backside of the dash for the nuts holding it on and remove them. It's an easy job.
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 02-06-2007, 09:06 AM
jaydubya's Avatar
Thank you! I'll have a better look...
'82 911SC racecar
'05 WRX STi
Old 02-06-2007, 09:25 AM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
any results?
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 11-02-2008, 08:13 PM
jaydubya's Avatar
It's just like Tom said above.
'82 911SC racecar
'05 WRX STi
Old 11-02-2008, 08:26 PM
I wondered too my dash is sagging a little by the ashtray.
1984 Porsche Carrera Cabriolet - sold, regrettably
2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably
2005 Mercedes C230 Kompressor Sport Sedan - now...
Old 11-02-2008, 08:34 PM
Yah you're a ****in liar guy, backside bolt nearest frunk release makes me want to ****ing kill myself.
Old 12-05-2023, 01:34 PM
Lol!
Old 12-05-2023, 01:40 PM
The bolts by the ash try are the easy ones the bolt by the ignition and the passenger door are the fun ones. Remove the seats get a compfy pillow a great flashlight lay upside down with your head on the clutch pedal nestled against the brake pedal and from hear you can remove the wiring that is mostly in you way. Be sure to for get to bring your 10 mm wrench and 1/4” ratchet with you that way you can climb in and out 6 more times. The repeat on the passenger side minus the pedals and use your left hand on these
Old 12-05-2023, 04:55 PM
The bolts on the Kneepad keep spinning im trying to remove them to replace the glove box. any suggestions on what to do.
Old 10-08-2025, 04:58 AM
