-   -   Is there a DIY for removing/installing the RH Intake manifold? (http://forums.pelicanparts.com/porsche-911-technical-forum/1075345-there-diy-removing-installing-rh-intake-manifold.html)
markmalin 10-10-2020 01:37 PM
I no longer have my Bentleys - long story.
Is there a DIY for R/R the right hand side intake manifold? Torquing specs, etc? Procedure for re-install?
Thanks - I wasn't able to find anything specific in the search - but maybe I didn't type in the right thing.
dwelle 10-10-2020 02:00 PM
for what engine?...
markmalin 10-10-2020 02:01 PM
Originally Posted by dwelle (Post 11059874)
for what engine?...
D'oh! I'm sorry. This is an 85 Carrera 3.2
yelcab1 10-10-2020 02:44 PM
There is really no need for detailed instructions.
1. Remove air filter box and the MAF
2. Reach back and detach all fuel regulation components from the intake runners
3. Use a long allen socket (8mm I think) to reach down and loosen all intake manifold nuts
4. Disconnect the large hose interconnect between right and left side manifold
5. Lift manifold up and out
Replace gaskets on the way back.
I would not go tighter than 20Nm on the way back.
markmalin 10-10-2020 03:21 PM
Sounds good. Thanks.
Mark
markmalin 10-10-2020 03:51 PM
I pulled the intake manifold on the right side... Came out easily.
So is there a gasket + spacer + gasket on each one? So I need to buy 6 gaskets and 3 spacers, or can the spacers be re-used?
Also that rubber adapter between the intake sides, it's pretty flappy. Is that typical, or is that spent as well?
Mark http://forums.pelicanparts.com/uploa...1602370261.jpg
dwelle 10-10-2020 07:34 PM
i'm in the middle of this due to a cracked fuel line. i opted to pull the entire intake so i can service the injectors and replace all of the gaskets and seals and clean everything up.
i'm also replacing the spacers and the rubber boot between the left and right side as they aren't too expensive...
markmalin 10-12-2020 06:17 AM
Any advice on getting the gasket material off the head? Mostly it lifted off, but parts are stuck. Just wondering what the best way is.
Mark
