Starting car for first time in years 1988 911
I'll be starting the car for the first time in many years and going through the maintenance list. What caveats can you guys share before I start. I have a tentative list. Updated:
1. Drain gas (sitting for several years). - I had the wrong tool, will try again this Saturday.
a. Pull remove filter strainer -
b. add fuel injector cleaner -
c. Pull test cap off the fuel rails -
d. Pump fresh gas through lines after filling tank with fresh gas -jumpering the fuse block and also by cranking the engine.
2. Flush brake lines - Completed.
3. Replace Battery - Completed.
4. Remove plugs. Once removed spin by hand.
5. Check Timing - (I'll have to read up on timing)
6. Change oil - Completed.
7. Disconnect the DME relay under the driver seat. Or, the injector plug (rear left by crossmember)
a. Then use the starter to get pressure up to 2 Bars - Hopefully this weekend I can accomplish this.
8. Look around for Mause - no mouse.
9. Fuel Line inspection: Test run fuel pump using fuses 16 and 17. How do I test run? I am turning the ignition to the "on" position before starting and letting it run in that position? I am pulling those fuses to do this test?
. Basic Maintenance
- plugs - completed
- Cap / Rotor - completed.
- Spark Plug wires:
- Air filter: Completed.
I didn't add the Mystery Oil, forgot to do that while I was replacing, will remove plugs this weekend again and add 2 tablespoons in the cylinders.
5. Tires: Ordered.
6.
Any tips are greatly appreciated.
Old 08-21-2020, 09:46 PM
Slow old car
Sounds like you’ve got the right idea. I’d add:
Spin it by hand with the plugs out, listen for any strange noises.
Check ignition timing while you’re doing that.
Change the oil.
Mike
1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX
Old 08-21-2020, 10:13 PM
Bill Douglas's Avatar
As Mike said, spin it by hand and get some oil floating around.
Old 08-21-2020, 11:46 PM
Disconnect the dme relay under the driver seat or the injector plug at the left side of the rear shock crossmember, then use the starter until the oil pressure gauge shows 2 bar. Be careful to hold the complete plug as you remove it so you don't just pull the cap off the plug and possibly pull the wires out of it.
206 637 4071
Old 08-22-2020, 03:25 AM
shh-the robot is sleeping
Clean out any mouse nests or other debris that may have collected. Take a close look at fuel lines. Have a fire extinguisher handy just in case.
'88 911 Coupe, 69k miles
Old 08-22-2020, 03:36 AM
Fuel leak test........
Test run the fuel pump using fuses #16 & #17 counting from the front. Let the fuel pump run for a few minutes and check for any sign of fuel leak in the system. Do NOT run the motor until you have checked and confirmed this test. Plus the other recommendations.
Tony
Old 08-22-2020, 03:38 AM
I just went thru the exact same thing 2 weeks ago.
1. I would pull the filter strainer from the gas tank after you drain the gas and before you try to crank it over or fill with new gas to get the sludge out of the system as part of draining the tank.
2. Add some good injector cleaner to the new gas when you refill.
3. pull the test cap off the fuel rails and pump fresh gas thru the lines after refilling with gas. Do this both by jumpering the fuse block and also by cranking the engine. Consider changing the fuel filter at this point
4. pulse the injectors to get them working as they may very well be stuck shut. you may need to tap them to help open them.
5. replace the air filter.
after you do all he prep to restart, if the engine doesn't start on it's own try spraying some starter fluid into the air intake snorkle. if it starts this way but not normally be prepared to pull the injectors and clean them and replace the injector seals. (ask me how I know this! )
6. post your questions and frustrations here and ask for help if needed
Dan O
84' 3.2 Targa
Old 08-22-2020, 04:52 AM
Thanks guys I've got a really good starting point and list sounds spot on. I've updated it for reference. I'll more than likely need a reference book as well.
A few things seem pretty straight forward, others I'll have to ask again.
Old 08-22-2020, 06:51 AM
IS300's Avatar
pics help too
Old 08-22-2020, 06:57 AM
I added 6 fl oz of STP octane booster to the 10 gals of new gas (91 octane) yesterday. My car sat a couple of years.
Old 08-22-2020, 10:54 PM
Caveat: I am a certified newbie so heed my adv w caution.
Old 08-22-2020, 10:58 PM
HarryD's Avatar
Check posts 20 and 21 by Grady Clay in this thread. Lots of great advice. Winter storage checklist?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-23-2020, 09:16 AM
Add some oil to the cylinders
Before starting, and while you have the spark plugs out, squirt some oil, such as Marvel Mystery Oil, into each cylinder and rotate the engine by hand a few revolutions. This will lubricate those dry cylinders before lighting it up. I used a few tablespoons in each cylinder.
The added benefit is that the smoke from the oil will add a very dramatic feature to the whole operation!
Old 08-23-2020, 10:27 AM
Ok thank you right on that. I'm looking for a pasts list for the Major tune up.
I don't know why I didn't have it on my Excel spreadsheet.
Old 08-23-2020, 10:33 AM
HarryD's Avatar
To me, a major tune-up (every 15,000 miles) consists of:
Replace filters (air, oil gas)
Replace plugs
Replace/adjust points (if present)
Adjust valves
Replace engine and transaxle oil
Adjust timing
Check CV Joint Bolts
Lubricate throttle linkages
Adjust clutch (if needed)
Lubricate hinges
Check/adjust wheel bearings
Check/replace brake pads and rotors (as needed)
Check/replace tires (if needed)
Harry
2020 MB E350 4Matic
Old 08-23-2020, 11:27 AM
Just put in an order for this. Thanks
Old 08-23-2020, 09:12 PM
An addition to others' suggestion to check for mouse debris. Borrow a borescope to snake through the cooling fan and look for nest material on the cylinders. Nest material will block air flow, possibly leading to broken head studs, or worse.
Tom Harris
1974 911 for track
1989 911 for street
Old 08-24-2020, 08:20 AM
I was trying to upload pictures of the 911 from Google Photos. I'll see if I can figure it out...
Old 10-17-2020, 05:51 PM
