how to remove interior backside trim panels
How do I remove these?
Start with the lower.
The two screws at the bottom of the face panel then slide up. There is a clip or two at the top. The the two screws that hold the leather straps and pull toward you. It slides under the rear window seal. There may be a clip in the middle too. Can't remember 100%. It's very basic.
Derrick |
Indeed, 4 screws and lift up, don't pull towards you, as the lip bends easily, or can even pull out of the cardboard backing.
Thanks !
