Bilstein Strut Insert
Evening.
Have a 1977 911s with Boge strut assembly. Ordered new Bilstein inserts from Pelican. Took apart passenger side and noted that there was no roll pin nor any holes for a roll pin.
Took old insert out and noted that it has a yellow sleeved Bilstein P36-112. Made in West Germany.
My issue is the new insert does not have the yellow tube and i can see no way to remove the yellow tube from the old and switch it over.
Old 01-07-2021, 03:40 PM
Rescuer of old cars
Arne2's Avatar
You've got the wrong inserts. The new ones without the sleeve that use the roll pin are for cars that came from the factory with Bilstein. You need inserts designed to fit Boge strut housings. Totally different parts.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-07-2021, 04:40 PM
Was worried about that. Thanks dude.
Old 01-07-2021, 04:50 PM
