Buy a large top-tapered funnel (like the orange or blue one ) with a wide filler neck and cut the bottom of the filler neck to size. You only need enough to stick down into the filler tube. Been using it for years
'82 911 SC |
Banned
'73 911 T Targa
Here’s a picture of my “Oil IV”. I fill the bucket with the appropriate amount oil and sit it or hang it somewhere higher than the fill. The end that goes on the fill has a valve to turn the flow on and off and a big magnet to hold it in place.
Almost Done
stoooopid question
when filling, I assume its important to avoid oil going into the "dipstick" tube or does it not matter? |
It does not matter. It all drains into the tank. The dipstick tube is just a holder to keep the dipstick handy. LOTS of people have dropped a dipstick into the tank. I never have because I always make sure it get it in the hole.
Glen 44 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
antifreeze funnel
I just use an antifreeze funnel. My daughter and I came up with a system where she pours it in while I open the container. She’s pretty good at pouring it right in without letting too much drip into the engine bay.
I purchased, from my local shop, a plastic jug with a flexible spout that holds 5L if oil.
It pours cleanly and just fill it twice (10L) and you're finished. The garages use them for a reason. They charged me $20 . For top ups I use a sm funnel that screws to the top of the litre (quart) jugs. |
$1.89 at Home Depot, cut a couple inches off the bottom. Fits securely in the filler neck and flows ~ 1 gallon in 10 seconds without backing up.
1978 SC Targa |
Banned
I have 2 of those long tranny funnels, and I cut out part of the top on one to make an empty slot for a bottle to sit in.
But I like the one below better: Quote:
or scan it - blow it up a bit and make a 3d printer run ------- we also have not had a rousing discussion of oil drain pans recently... |
Sorry... I'm getting too old to be "hunched over" while hand pouring 10 qts of motor oil ...
This is definitely NOT your low cost option...but works great for me and my back. The plastic funnel with a 1" NPT thread was $12US on Amazon. Fortunately for me...the copper fittings and pipe were leftovers and scrap... All I do is zip-tie it tight to the engine cover hinge, dump in a quart of SWEPCO, and walk away for a few minutes while I open and prepare the next quart. The copper never touches any painted surface, like the fender, and I normally have a towel there for any drips, but didn't for the photo ![]() ![]() ![]() |
New-ish 911SC Targa Owner
I like the ability to walk away with this one! Nice solution you have there
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp '05 E500 wagon in minty cond '13 Volvo XC60 (hers) |
I have a funnel from Redline to change the oil on my Guzzi. It works pretty well on the 911 too.
Banned
I'm gonna build one - be nice if it took 1 gallon containers |
Guy over on Rennlist built something similar using PVC fittings. Be much cheaper.
Walt 81SC with 3.6 & 82SC stock |
I will cut the bottom off as you have done.
1977 911S Targa 2.7L (CIS) Silver/Black 1998 Chevy S-10 4x4 Pick-Up Truck, Razzle Dazzle Camo 1989 modified Scat II HP Hovercraft George, Architect |
1958 356A - Sold to a rust collector 1978 924 - sold to a sewing machine repairman 1984 944 - meticulously maintained but everything except the drivetrain self-destroyed. Used in trade for my wife's MB 1988 Carrera 3.2 Targa - purchased in 1992 and still thriving. Boy, do I love this car |
Thread Tools | |
Rate This Thread | |
