-   -   Oil Change Funnel (http://forums.pelicanparts.com/porsche-911-technical-forum/1075861-oil-change-funnel.html)
Missed Approach 10-16-2020 06:09 PM
Oil Change Funnel
Spills, drips, mess. I couldn't take it anymore. Tonight was her scheduled oil change and with my recent decision to use 5 qt. Jugs, a modification was in order. That green sheet is a flexible cutting board. It was cut to fit the standard yellow radiator fluid funnel. I attached it with gutter screws. It's not pretty, but it works. Also... always nice to not find anything ferrous attached to the magnetic drain plug.
http://forums.pelicanparts.com/uploa...1602896698.jpg
Cooking on a Porsche 911- The compound butter made the difference.
<iframe width="560" height="315" src="https://www.youtube.com/embed/FvXBR50rH9E" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
john walker's workshop 10-16-2020 06:34 PM
Here's mine for that screw on filler, mostly for 964s due to their slow fill for the last 5 quarts.
http://forums.pelicanparts.com/uploa...1602898399.JPG
Arne2 10-16-2020 09:58 PM
I used a 40 year old offset funnel similar to the one John posted for almost 9 years with my '84 Carrera. Finally gave up and replaced the Carrera with a '72 911T with external oil filler. Problem solved! :D ;)
Well, the oil filler wasn't really why I bought the '72. But it's a nice side benefit.
http://forums.pelicanparts.com/uploa...1602910618.jpg
Rodney Nelson 10-16-2020 10:15 PM
Awesome year! Awesome Color!
proporsche 10-17-2020 03:18 AM
what is your trick of removing the oil filter on 964??Since is always a big mess;-)
Ivan
nice funnel you made ..the the OP;-)
Ivan
OldSpool87 10-17-2020 06:38 AM
I know this is a bit of a thread hijack...does anyone have tips when removing plug on engine cases with no sump plug but only side mounted plug? In my set up, the B&B heater boxes are pretty close to the side drain. I always end up mocking up a “curtain” for the oil to hit as it gushes out. Never a clean job...
porsche930dude 10-17-2020 06:52 AM
I have one like this. Mine is old but they still make them. Do it from over the fender. Expecially now my lid doesnt open as far as it used to with the spoiler on it.
http://forums.pelicanparts.com/uploa...1602942608.jpg
Locker537 10-17-2020 06:57 AM
Walmart sells some large cheap funnels that I find work well.
john walker's workshop 10-17-2020 07:18 AM
[QUOTE=proporsche;11067497]what is your trick of removing the oil filter on 964??Since is always a big mess;-)
Drain tank and engine, leave the tank plug off, put a pan under the tank, loosen oil filter to just hand tight, punch a hole at 12 p'clock and use a rubber tipped air gun to blow the oil out of the filter, into the tank for about a minute. No mess.
mike sampsel 10-17-2020 09:09 AM
[QUOTE=john walker's workshop;11067651]
Clever, I'll assume a similar method would work with the SC filter?
proporsche 10-17-2020 09:13 AM
Hi John..i figured you might say this;-) i do the same plus i use compressor air and blow into the oil filter;-) but as you said, gravity is magic............
Ivan
walt 10-17-2020 12:00 PM
This would make a nice 3D printer project for someone with the initiative. The perfect 911 funnel, I'd buy it.
Been using the one in post #7 for years. Works fine but slow.
proporsche 10-17-2020 12:05 PM
Mike.in 911 there not much of a problem when you remove the filter but 964 major PITA...for peeps who do not know ....this thread should help
Ivan
Walt what`s the rush;-))))))
anglophone1 10-17-2020 02:31 PM
Et voila!
https://www.impactbumpers.com/forum/index.php?/topic/36442-ib-oil-tank-hands-free-funnel-3d-printed-solution/&tab=comments#comment-410288
I have one - elegant solution
Missed Approach 10-17-2020 02:53 PM
Hi Anglophone1 -Thank you- that's beautiful! I will email ajd directly (beats my cutting board & sheet metal screw solution by a mile).
porsche930dude 10-17-2020 03:29 PM
Thats cool! It would be better if the neck was longer to go down in past the breather tube. Im always afraid of oil getting in there my car smokes enough as it is
tdw28210 10-17-2020 04:26 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/1031690-oil-add-trick.html
PhillIB 10-19-2020 11:19 AM
This is what you need to do. Bigger than AJDs. AJs was more popular. We ended up developing them at the same time.
https://www.impactbumpers.com/forum/index.php?/topic/35795-ib-oil-tank-hands-free-funnel-drainpipe-solution/
GH85Carrera 10-19-2020 11:57 AM
http://forums.pelicanparts.com/uploa...1603133175.JPG
This was my solution that I take with me on road trips to add oil. It all fits into a zip lock bag and does not make a mess. The blue part comes free with aviation oil that we buy by the case. I can put the cap on, and stuff a paper towel in the top, and place in the zip lock bag and no mess for road trips. No glue will stick to that plastic very well, so I reinforced the epoxy with the electrical tape. It is small and compact and that is a real bonus on the road.
http://forums.pelicanparts.com/uploa...1603133274.jpg
Pelican sell this little tray. It uses a magnet to stay in place. The oil stays in the tray and is easy to sop up with a paper towel. It is form fitted to fit perfectly in place and it works.
I have a long funnel that works great for regular oil changes in my garage.
MBAtarga 10-19-2020 12:36 PM
Guy over on Rennlist posted a thread just yesterday on this funnel at Walmart that's just over $1. It's sold as a funnel for DEF, but looks like the shape would be perfect for the 911 oil fill neck. It was recommended on Rennlist for the 997TT models.
https://www.walmart.com/ip/Hyper-Tough-DEF-Diesel-Exhaust-Fluid-funnel-10732WRHT/370116357
http://forums.pelicanparts.com/uploa...1603136155.jpg
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
