That's fond- just deglaze
Oil Change Funnel
Spills, drips, mess. I couldn't take it anymore. Tonight was her scheduled oil change and with my recent decision to use 5 qt. Jugs, a modification was in order. That green sheet is a flexible cutting board. It was cut to fit the standard yellow radiator fluid funnel. I attached it with gutter screws. It's not pretty, but it works. Also... always nice to not find anything ferrous attached to the magnetic drain plug.
![]() ![]() ![]() Cooking on a Porsche 911- The compound butter made the difference.
Missed Approach Petra- 1986 Coupe |
Here's mine for that screw on filler, mostly for 964s due to their slow fill for the last 5 quarts.
Rescuer of old cars
I used a 40 year old offset funnel similar to the one John posted for almost 9 years with my '84 Carrera. Finally gave up and replaced the Carrera with a '72 911T with external oil filler. Problem solved!
![]() ![]() Well, the oil filler wasn't really why I bought the '72. But it's a nice side benefit. ![]()
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s 1972 911T coupe Priors - '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Sold, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold |
what is your trick of removing the oil filter on 964??Since is always a big mess;-)
Ivan nice funnel you made ..the the OP;-) Ivan
1985 911 with original 495 067 miles...796 732 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I know this is a bit of a thread hijack...does anyone have tips when removing plug on engine cases with no sump plug but only side mounted plug? In my set up, the B&B heater boxes are pretty close to the side drain. I always end up mocking up a “curtain” for the oil to hit as it gushes out. Never a clean job...
I have one like this. Mine is old but they still make them. Do it from over the fender. Expecially now my lid doesnt open as far as it used to with the spoiler on it.
82 SC , 72 914 |
Walmart sells some large cheap funnels that I find work well.
[QUOTE=proporsche;11067497]what is your trick of removing the oil filter on 964??Since is always a big mess;-)
Drain tank and engine, leave the tank plug off, put a pan under the tank, loosen oil filter to just hand tight, punch a hole at 12 p'clock and use a rubber tipped air gun to blow the oil out of the filter, into the tank for about a minute. No mess.
Targa_PB_78_SC
[QUOTE=john walker's workshop;11067651]
BareRearedRookie |
Hi John..i figured you might say this;-) i do the same plus i use compressor air and blow into the oil filter;-) but as you said, gravity is magic............
Ivan
This would make a nice 3D printer project for someone with the initiative. The perfect 911 funnel, I'd buy it.
Been using the one in post #7 for years. Works fine but slow.
Walt 81SC with 3.6 & 82SC stock |
Mike.in 911 there not much of a problem when you remove the filter but 964 major PITA...for peeps who do not know ....this thread should help
Ivan Walt what`s the rush;-))))))
Et voila!
https://www.impactbumpers.com/forum/index.php?/topic/36442-ib-oil-tank-hands-free-funnel-3d-printed-solution/&tab=comments#comment-410288 I have one - elegant solution |
Hi Anglophone1 -Thank you- that's beautiful! I will email ajd directly (beats my cutting board & sheet metal screw solution by a mile).
Missed Approach Petra- 1986 Coupe Last edited by Missed Approach; 10-17-2020 at 02:01 PM.. |
Thats cool! It would be better if the neck was longer to go down in past the breather tube. Im always afraid of oil getting in there my car smokes enough as it is
82 SC , 72 914 |
Cars and Cappuccino
http://www.carsandcappuccino.com 1987 Cherryrot G50 Coupe - SOLD 1985 Prussian Blau M491 Targa - 1 of 65 in the US 1977 Mexico Blue flared, 3.2, back date, sunroof-delete Coupe - under refinement. 1972 Black T coupe to Longhood Turbo R5 tribute car (someday) |
This is what you need to do. Bigger than AJDs. AJs was more popular. We ended up developing them at the same time.
https://www.impactbumpers.com/forum/index.php?/topic/35795-ib-oil-tank-hands-free-funnel-drainpipe-solution/
Phil 1978 911SC Megasquirt2 with ITBs |
This was my solution that I take with me on road trips to add oil. It all fits into a zip lock bag and does not make a mess. The blue part comes free with aviation oil that we buy by the case. I can put the cap on, and stuff a paper towel in the top, and place in the zip lock bag and no mess for road trips. No glue will stick to that plastic very well, so I reinforced the epoxy with the electrical tape. It is small and compact and that is a real bonus on the road. ![]() Pelican sell this little tray. It uses a magnet to stay in place. The oil stays in the tray and is easy to sop up with a paper towel. It is form fitted to fit perfectly in place and it works. I have a long funnel that works great for regular oil changes in my garage.
Glen 44 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Guy over on Rennlist posted a thread just yesterday on this funnel at Walmart that's just over $1. It's sold as a funnel for DEF, but looks like the shape would be perfect for the 911 oil fill neck. It was recommended on Rennlist for the 997TT models.
https://www.walmart.com/ip/Hyper-Tough-DEF-Diesel-Exhaust-Fluid-funnel-10732WRHT/370116357 ![]()
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 |
Thread Tools | |
Rate This Thread | |
