Brake Fluid Level
How high up should the brake fluid level be? The fluid looks to be clean and the car stops fine. Any recommendations for for a 1977 911S to top it off?
Thanks Sam https://www.flickr.com/photos/124038604@N05/50501725037/in/dateposted-public/ |
When was your fluid last flushed? Yours looks dark. You "should" flush it every 12-24 months. Fluid should be clear.
I top my fluid to the mold line on the reservoir.
Ok Thanks Harry!!!!
Will this brake fluid work? 1977 911S
ATE Super Blue Brake Fluid Dot 4 |
Same as the ATE Typ200 just dyed blue. I used to alternate between ATE Typ200 and ATE Blue until they took the blue off the USA Market. What is nice about alternating is that you will see a distinct color change when you flush (blue to gold or visa-versa). In my 1973 with M Calipers, it takes no more than 170 ml per caliper to completely flush each caliper (the furthest uses the most and the closest the least).
Great This helps! Thanks again Harry
Sam |
