-   -   Tachometer Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/107607-tachometer-questions.html)
Matt in Japan 04-22-2003 05:37 PM
Recently, I have noticed that my tach likes to jump around a bit. This usually happens during acceleration - while the engine sounds like it's accelerating smoothly, the tach will pause at (for example) 2000 RPM and then jump to about 4000, or whatever speed I'm running. Almost like it's having a delayed reaction.
Does anyone know what causes this and how to cure it?
Thanks...
Matt
1977 Porsche 911S
Alan Cottrill 04-22-2003 06:14 PM
do you still have points?
Matt in Japan 04-22-2003 06:23 PM
Yes. I have them gapped properly at .35 mm and I have my timing set at Z1, since mine is a ROW model.
Alan Cottrill 04-22-2003 07:40 PM
I had the same problem and when I changed to a petronix ignitor it went away.
I didn't change to the petronix to fix the tach problem but it seemed to fix it.
does it seem to be worse on rainy or very humid days?
Jim Sims 04-22-2003 07:59 PM
On my '76 California spec 2.7 a "bouncing" tach means the point dwell is too far off; I found that it's hard to get the dwell set with just a feeler gage. The gage was just a starting point and to finely set the dwell required a dwell meter. Jim
Alan Cottrill 04-22-2003 08:23 PM
i've always wondered to set the dwell do you have to pop the cap, make an adjustment, put the cap back on start the engine check the dwell stop the motor pop the cap make an adjustment and so on and so on?
Jim Sims 04-22-2003 08:47 PM
Yeah; it's too bad Bosch didn't use the nifty (GM?) distributor/point design that had the little window or shutter in the side that allowed one to stick a small hex wrench in and adjust dwell while the engine was turning/running. Jim
Alan Cottrill 04-22-2003 08:49 PM
I'd buy 10 ignitors not to go through that
RoninLB 04-22-2003 11:32 PM
Haven't done it yet on the stock CDI/points.. but on the old ignition systems I used to remove the cap, hook up dwell meter, and have someone turn the key while I set the points as I read the meter.........Ron
CamB 04-23-2003 12:31 AM
I do what Ron does (on my BMW), except on a front engined car you can set up the dwell meter so you can see it when you crank...
Also interesting to leave it connected and rev the engine. My BMW's dwell changes a lot, indicating the distributor is very very tired...
Matt in Japan 04-23-2003 06:45 PM
Looks like I'll be picking up an ignitor pretty soon. From the discussions I see here, it seems to be the best solution for many different reasons. I have heard differing opinions on the Pertronix and the Alison-Crane. Any suggestions?
BTW, thanks to everyone for helping me out...
Matt
Alan Cottrill 04-23-2003 10:35 PM
if your distributor shaft has any play side to side I'd recomend the crane.
the crane unit uses a rotating disc with 6 slots cut in it. The optical sensor senses the light through the slots to trigger the ignition. If you have any play it won't be affected.
with the petronix if you have play in the distributor shaft you may have a problem with the gap between the rotating unit and the pickup changing.
if you have vertical play in the shaft (shaft moves up and down/in and out) you may also have problems lining up the rotating part with the pickup.
I've had good luck with the petronix but I see the merits of the crane unit.
