Oil Sump Plate - Clearance - 993
We are running a new 993 pump in a 3.0 case.. The oil strainer sticks out a little far and I thought using a locally sourced domed plate would work, but the threaded portion interferes with the strainer... So assuming that is a bad idea, would a domed plate without the drain plug clear?
Failing that, would this a/m sump cover from Pelican work? It does say for use with 993 pump, but looking at the photo, the domed part looks fairly shallow... https://www.pelicanparts.com/More_Info/MCD99310700100.htm?pn=MCD-993-107-001-00&bt=Y&fs=0&SVSVSI=790#tab4 |
Yes it fits. I just installed it on my 3.0 case with a GT3 pump.
‘70 911E ‘82 911 SC Targa ‘86 944 Turbo ‘90 OM606 Swapped SWB 300GD IG: @JackSchroederCreative |
