-   -   911SC A/C relay wiring diagram help! (http://forums.pelicanparts.com/porsche-911-technical-forum/1076320-911sc-c-relay-wiring-diagram-help.html)
bergfurher 10-21-2020 04:06 PM
I need a little help with the wiring diagram for a 911SC to 911 Carrera. The A/C relay in the smuggler's box has a yellow wire on it. I sold my factory workshop manuals years ago and now need them back! I just cannot figure out where the small Yellow wire goes to or comes from.
gerakroo 10-26-2020 12:14 PM
The small yellow wires comes from 85 (relay) and connects to the starter wire (50) from the tunnel harness.
bergfurher 10-27-2020 04:12 AM
Thanks, so energized from the starter.
timmy2 10-27-2020 07:38 AM
Actually used as a ground path for the relay coil when starter solenoid isn't picked up. That way compressor doesn't run on start up.
One of Porsche's unique wiring choices... :)
