-   -   wrong stop position rear wiper Targa 86 (http://forums.pelicanparts.com/porsche-911-technical-forum/1076345-wrong-stop-position-rear-wiper-targa-86-a.html)
alexandervdr 10-23-2020 11:34 AM
My wiper rests in the middle of the rear window. I assume this is not the correct position, but should be resting at the left side. What is wrong here?
http://forums.pelicanparts.com/uploa...1603481612.jpg
stevie 77 930 10-23-2020 01:44 PM
lift the wiper from the window (avoid scratching) and cycle through wiper on and off a few times. Observe the resting point each time. Once you have determined that spot, reposition the wiper to the driver's side of the glass. The wiper blade should rest in a vertical position.
Not my car.... but here is what its suppose to look like
http://forums.pelicanparts.com/uploa...1603489386.jpg
alexandervdr 10-23-2020 02:19 PM
are you sure about this? In my case the wiper goes from the mid position to the left , so if I reposition the arm to the left, it will move over to scratch the body no?:(
Arne2 10-23-2020 05:04 PM
Correct. Don't reposition the arm if it sweeps to the left, then all the way to the right and finally back to park in the middle.
Instead, you need to re-adjust the arm on the wiper motor. As I recall, the arm on the wiper motor should point straight to the right when parked.
alexandervdr 10-23-2020 09:54 PM
makes sense , tnx
alexandervdr 10-26-2020 11:40 AM
adjustment can be done with everything left in place. Just loosen the nut that holds the arm with a 10mm ratchet, unscrew it as far as possible but still holding some threads (putting the nut back on afterwards seemed like a challenge given the A/C radiator I have in). Pop the arm upward away from the motor with a fat screwdriver (it holds on a conical spline), and rotate it till the wiper arm is in the correct left position (in my case that was a 90° rotation). Tighten the nut. That's it ;)
http://forums.pelicanparts.com/uploa...1603741085.jpg
