Burnt gauges
I reinstalled my gauges the other day. Following the marks I made and a pic from the tech articles. When I got it all together and kicked the key on, the two red/blk wires that connect to a black bulb holder on the oil pressure combo gauge FRIED. So I quickly unhooked everything. No major damage except for the burnt up wires. My questions is:
What is the proper way to fix this and does anyone have a pic of the back of their gauges? |
so probably your red/black wires hit a ground behind the gauges somewhere.. the wire comes off the ignition switch, and is common to all the gauges, probably.. so you may have to inspect the whole red/black wire back to the ignition switch.. it's not fused from the switch.. it appears to be a big PIA.. better it happened while you were able to stop the possible car fire.. maybe you should do a complerely new wire and install a fuse..............Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks. My model is under my handle BTW.
