Always Be Fixing Cars
Heater flap box cable length mystery - too short on D/S, fine on P/S
In March I replaced the P/S flap box cable with part 911-424-701-01-M260, and found that if anything the cable was slightly long. If I recall, I bent a 180deg end on the cable to ease threading it thru the conduit, then cut that off and still had enough cable to let the flap close fully.
Today I replaced the D/S cable, same part number (checked my old order before re-ordering, checked part number of cable received). Did NOT bend a 180 in the cable, used it exactly as I received it, and found that it only kisses the hole in the retaining bolt. I'd need to "preload" the flap in order to fasten the cable to the bolt, giving me unwanted heat, which is why I tore the whole mess down to begin with!
Maybe I'm missing something, but I can't see where there'd be any adjustment in this system. I tugged on the free end of the cable to see if there was slack but didn't get more than a few mm.
My car is an 87 with manual (3 position switch) heat.
Any ideas?? Failing ideas, anyone know if any of the other cables are longer?
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 11-02-2013, 12:15 PM
Scar the 911
rogus's Avatar
Bummer I have the similar issue right now with the same part number and new guides but the wire is barley outside of the tube when its backed against the tunnel
Current: 1970 911T 2.2l
Past: 1981 BMW 320i, 1967 VW Beetle Deluxe, 1966 Volvo 122S
Old 07-30-2020, 04:25 PM
GothingNC's Avatar
I have the same issue for the D/S with my 82 Targa, manual heat when I replaced both of the cables over the weekend.
Took about an hour with 4 hands to finally fish the cable through the fastening bolt.
Thankfully it does not blow heat when it is turned off.
Is there a different part number for each cable?
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 10-26-2020, 09:18 AM
Wildman Emeritus
Subbed. On my project list.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-27-2020, 06:42 AM
creaturecat's Avatar
the cable is physically shorter than the one that was removed? the generic ones from Pelican could be slightly longer. any shorter - no work, in my case.
the cable sheath is fully inside the "mount" at the trans mount crossmember area?
Old 10-27-2020, 10:33 AM
GothingNC's Avatar
Heater cable guide tubes are fully inserted into the bulkhead tubes.
Cable going to the passenger side had about 2 inches extra length past the faster.
Both of the new cables were equal length.
Maybe the D/S was shortened a little bit when it was tied to the hand controls,
John D.
2012 Golf TDI
Old 10-27-2020, 10:45 AM
