Oil line loose 3.2
My oil line hose from oil tank turns on the crimped pipe end pretty easily , is this normal? I would think that if crimped tight , it should not turn. I'm not sure if it has been leaking, since I had leaks else where that I have now fixed. If this is not normal hopefully a local shop can crimp a new hose on for me .Thanks for your input.
Old 10-24-2020, 09:24 PM
Not normal. You need a new hose.
Porsche 2005 GT3, 2006 997S
Exotic: Ferrari F348TB Factory Challenge, Ferrari 328 GTS
Disposable Car: BMW 530xiT, Audi A3S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-24-2020, 10:35 PM
BoxsterGT's Avatar
Porsche Crest
Perhaps you can find a local shop to Re-Hose your Feed to the Thermostat as this....
Just be careful they use the correct crimp jaws and crimps. Most have Crimps & Jaws that are too long.
Len
Old 10-26-2020, 03:24 AM
Flojo's Avatar
NO, absolutely NOT.
fix/replace asap!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Parts: https://www.instagram.com/spadescustomz_/
EGO: https://www.instagram.com/911garage_germany/
Old 10-26-2020, 04:32 AM
Not normal. and getting that other end off from the thermostat is often a real hard chore.
Either get a new hose, or see if there is a local shop that can get a good crimp on your fittings. It is metric hose, and be 100% certain it is done right. It is under pressure, and could empty the oil system in seconds if it fails.
44 Year member of the Porsche Club of America
Old 10-26-2020, 07:32 AM
A new hose is not that expensive. Beats getting it repaired.
Old 10-26-2020, 08:18 AM
Great , thanks for the help ! Hopefully it won’t give me that much trouble breaking it loose from the thermostat.
Old 10-26-2020, 07:33 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Yes, this could be problematic. Even with the whole system removed from the car I could not get it off without taking a change of stripping the thread off the cooler (very expensive).
So I carefully slice the nut with a Dremel and use aftermarket replacement nut. https://www.pelicanparts.com/More_Info/ERMP0170000.htm?pn=ERMP-0170000&bt=Y&fs=0&SVSVSI=803
Never leak after it was replaced. I'll post pictures tonight.
Who Will Live... Will See
Old 10-27-2020, 02:29 AM
On my 1985 I replaced that exact same oil line for the same reason, it was seeping oil. I started soaking it with penetration oils for a couple of weeks before I tackled it. With lots of cussing and fighting I got it off and did not hurt any threads on the thermostat. Many people have removed the thermostat from the car, and put it in a vise to have better access to it.
Read the many threads on the board about how others have done it.
Good Luck!
Old 10-27-2020, 08:12 AM
nene's Avatar
When I replaced mine, I found myself using a dremel to cut off the thermostat side nut, which worked great.
Serge
Old 10-27-2020, 08:22 AM
JJ 911SC's Avatar
Elephant Racing 30mm Tube Nut Replacement
Old 10-27-2020, 04:19 PM
