oily wire
1987 Carrera
I detached #3 cylinder distributor wire from the spark plugs to examine it and I found it to be covered with oil...is this normal?
Old 10-29-2020, 11:52 AM
No it's not. Photos please. Could be valve cover gaskets or other (many) issues.
Old 10-29-2020, 12:01 PM
oily wire
The stem that connects to the spark plug has a black rubber section with the connector pin and a metal part. It was the metal part that was covered with oil...the rubber section covering the spark plug was dry...
Old 10-29-2020, 12:41 PM
Uncertifiable!!!
Uwon's Avatar
Yep, likely valve cover gasket, or, loose/leaky rocker pin.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 10-30-2020, 04:22 AM
