Shallow dish Momo Veloce... which hub?
I have just picked up a nice old period correct Momo Veloce for my 3.2.
I have no issue with the reach to the stock 4-spoke 380mm wheel.
I want to use the JWE eccentric adapter with this 350mm Momo... do I want the short C231 or long L231 hub?
Old 10-29-2020, 07:10 PM
Do you have a standard or extended hub factory wheel? What is the dish of this wheel?
The C231 is 94mm and L231 109mm. I believe the JWE is 17mm. Add the measurement of this wheel and compare to your current setup. An L231 with JWE and Prototipo (39mm) is almost exactly the same reach as the factory extended hub wheel.
1989 Carrera
Former flings...
2009 Carrera S (x2), 1986 Carrera, 1997 993, 1983 911SC, 1995 993, 1987 Carrera, 1985 Carrera
Old 10-29-2020, 08:24 PM
My factory wheel is not the extended version. The dish on this one is about 25mm.
Mark
1987 3.2 "Nancy's ride" ('cause Nancy owned it for 27 years before me)
1984 3.5 “Charley” (Charles owned it for 27 years)
Old 10-29-2020, 09:11 PM
018 extended hub wheel is about 170mm and the standard wheel is about 140mm. C231 with JWE and your wheel will be about 136mm and the L231 with JWE will be 15mm closer.
1989 Carrera
Former flings...
Old 10-29-2020, 11:13 PM
Flojo's Avatar
Originally Posted by Marko888
I want to use the JWE eccentric adapter with this 350mm Momo... do I want the short C231 ..]
this
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 10-30-2020, 01:17 AM
For reference... Momo Adapters - The Long & Short of it...
Old 10-30-2020, 03:10 AM
Thank you.
Mark
Old 10-31-2020, 08:42 AM
