pcm3.1 for 991
Hi all. im a new owner of 2014 991, i had a problem with my PCM3.1 system [ after tried to install the apple play circuit board inside the pcm, now the system is not turn on at all ]. i want to buy a used pcm3.1 on ebay for replacement, all cables behind the used pcm and the buttons are the same as my system.the question is does the replacement unit just plug and play or required dealer service.Please advise
Old 08-09-2022, 06:46 PM
Bobflat6 -- this forum focuses on air-cooled classic 911s, you'll likely have much better luck with your 991's PCM issue on pelican's water-cooled 996/998/991 forum (https://forums.pelicanparts.com/porsche-996-997-991-forum/) or over on the technical forums on rennlist.com
Best of luck!
Old 08-10-2022, 10:56 AM
