Roof wiring 911 coupe
Hi my car return from the paint shop and someone have pull to the trunk the harness for the interior dome lamps and the harness for the solar roof motor , i know it run inside the pillar ,left for the solar roof and right for the dome lamps but i not find the holes or passages to access to pillars for pull up the harness in place.
If anyone have a picture from were are located this passages send me it or any information to tray to find its.
I tray for two weeks whit no luck.
Thank in advance
Old 11-01-2020, 12:58 PM
I would rather be driving
jpnovak's Avatar
start inside the roof at the top and fish a pull cable from the top down. It will exit in the trunk space in the far corners. you will have to really reach for it up in there. Then use the pull wire to pull the wire up into the roof space.
Why did the pull them out? I only pull if required to weld on the cowl or pillar.
Old 11-01-2020, 03:04 PM
Thanks Jamie , i have tray to do this to but the wire go to the bottom of the pillar close to the rocker panel and not find the way to go to trunk , the two sides is the same problem , i need find the outlets in trunk for go up from this point.
Best regards
Rudolf
Old 11-02-2020, 03:41 AM
Access inside where heat tubes run, just above map pockets.
Old 11-02-2020, 04:13 AM
Old 11-02-2020, 04:15 AM
Thanks Dpmulvan , and you know were is place the access outlet to the trunk , i need find it because the harness depart from inside it.
Old 11-02-2020, 05:22 AM
