Interior Dome Light Wiring
I tried to install new wiring for the interior dome lights and ran into a snag. The wiring runs from the roof down the passenger side A-pillar and into the front trunk area to connect to the main harness. I managed to snake a long stiff wire up from the trunk into the A-pillar, and connect it to the wiring, but I can't seem to pull it back down. It seems to get stuck at the bend in the top of the A-pillar, as if the wiring and connectors are too wide. Anyone know of any tricks or tips?
Jason '73 911 Carrera RS clone w/3.0 |
Jason... if snake's end has any config similar to a hook / barb---even a small one---that may be what's getting caught up. Or perhaps when wire is attached to snake there's a bulb'd area that's too fat to make return trip. If there's a hook/barb, try to rotate wire. Perhaps that will allow hook to pass obstruction it's hanging up on. If no go, eliminate hook/barb or wrap with tape---but adding tape defeats recommended diet coming as next avenue. If there's a bulb'd area... give it a "diet." Can test passage diameter by wrapping wire with tape and progressively reducing amount of tape on wrap until it makes return trip successfully. Perhaps connectors have to go and be reinstalled once wire is snake'd.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Hi , i have a similar problem whit my 1977 930 , someone pull inside the trunk the wire harness for the dome lamps and the harness for the solar roof , this is do in the paint shop and now i need to find the connecting hole from the trunk to the left pillar for the dome light wiring and the other in the left side for the sun roof harness , the problem is i tray to find this holes for two weeks without luck.
If anyone knows were they are located please give me this information. Thanks in advance |
