I do take accurate torquing seriously, from CV bolts to lug nuts and a bunch in between. As well as valve cover nuts. My range goes from lb in to 300 lb ft with a torque multiplier I can accurately torque to over 1200 lb ft. Mind any error is multiplied, but at those levels +/- 10% is usually acceptable. |
I would suggest for everyone to pick up one of these little bad boys: https://www.amazon.com/gp/product/B004VYURT0/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
They are certified at sale and very good for checking your other wrenches (stick the gauge on a normal torque wrench) to see how they are. I found my craftsman 1/2" clicker was creeping up in torque every time it reached the limit until I spun the ratchet some, and max torque depends on how quickly I turn it. Anyway, using the gauge I did my joints a little while ago and a couple hundred miles later each one is perfect. No moon washers and no schnorrs. Edit: I used only the hardware that came with the GKN/Loebro units through pelican. |
| All times are GMT -8. The time now is 10:58 AM. |
