Exhaust nuts & bolts...
What is recommended for replacing the bolts in the exhaust system flanges?
Basic steel or stainless steel?
Old 11-03-2020, 10:33 AM
Regular old steel. SS can bind/gall on itself on removal.
206 637 4071
Old 11-03-2020, 10:56 AM
proporsche's Avatar
i like to use regular steel nuts..The only think out of ordinary i do is .I change them every year one by one so they do not get rusty..is a cheap solution to prevent the oxidation ...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-03-2020, 01:04 PM
I just replaced my steel muffler with a stainless Monty. There are some interesting threads in this forum about stainless. I suggest you read through them. I ended up using stainless bolts with silicon bronze nuts. Someone posted a chart showing how metals react to each other. The chart is very useful understanding how different metals interact.
The steel nuts and bolts I removed were SAE. They fit too tight. They were rusted. 3 came off with a hammer and a cheater bar. The last one fought me a bit.
1966 912 to 2.7 Frankencar
Old 11-03-2020, 01:31 PM
3rd_gear_Ted's Avatar
Use a six point deep socket also.
Some thin wall nuts are 12mm, others are 13mm.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 11-03-2020, 01:54 PM
KNS KNS is offline
For my Cat Converter and Muffler hardware I used stainless steel bolts and silicon bronze nuts. They will never rust, seize or gall. In fact, over ten years later they still look like new. I had the Cat Converter off just recently and the hardware came off easily with hand tools.
Kurt
Old 11-03-2020, 02:09 PM
donbecker1234's Avatar
Read elsewhere on here that Chris @ TurboKraft recommends allen head SS bolts with copper nuts and high temp antisieze. That's what I went with.
1987 M491 Widebody, Nautic Blue / Linen with a 1979 930 3.3L Cali Engine
Old 11-03-2020, 03:19 PM
famoroso's Avatar
Recent thread with chart...
Exhaust Hardware Questions
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 11-04-2020, 05:12 AM
Thank you for posting that link Frank. .. really superb info. Frank
Old 11-04-2020, 06:19 AM
