lateapex911's Avatar
Fiberglass fan shroud painting? E shroud green paint color??
So, I looked and probably missed the thread already about this, so feel free to scold me and point me in the right direction lol.
I'm refreshing the engine, and when it's out I might was well, since I'm there, repaint every last thing
So far I'm Cerakoting the fan, valve covers tins etc etc.
I went to clean up the fiberglass fan shroud. The car is a 1973 E in yellow. Back on the 90s, the 2.4 had issues, the MFI needed rebuilding, and Gus was backed up like a year, soooo my builder put in 2.7 with solex cams and 6 webers, a pretty standard build. My green shroud went away and the new 9old) one was black. And used.
Today, it's not great, scuffed up, stained and looks like it's been used for 40 years! Some of the rivets are MIA.
So, questions:
Rivets: are there proper stock style I should use? Or just the crappy ones I have with my 30 yr old cheapo rivet kit?
Paint: were these painted at the factory or is the color integral? And if I repaint, what color? I was thinking I could go with satin black, or green as thats the stock color as built and I like the look, but it's kind of a lie as it's not an MFI E engine. Thoughts?
Prep: Body fill the scratches and other blemishes? From the factory, the surface shows the raw material. So I'm thinking don't go overboard, leave as much stock as possible, just clean up the ugly damage.
OR?
Maybe raw fiberglass in amber? I assume that's made by somebody but likely costs a month at Yale. $$.
Any other tips, tricks or advice "while I'm here"?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 02-14-2021, 10:21 AM
There seems to be a contingent of owners who fall into the, “never paint the engine shroud” camp. While delegates of the, “it’s your car, do what you want” tribe may offer up experience and expertise for refinishing materials and techniques.
When I purchased my car, “I didn’t know any better” so I can claim ignorance. I just knew my shroud looked a bit dull and grungy. A thorough cleaning and some rattle can paint made it look almost as good as new. I won’t tell if you don’t.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 02-14-2021, 08:38 PM
otto_kretschmer's Avatar
years ago I replaced my alternator and since the fan was out I rattle canned it flat black and it still looks good
if you got holes to fill I would use JB Weld over bondo but it probably won't make much of a difference. I would expect JB Weld to outgas less than the polyester resin based bondo when the fan shroud is heated.
flat black is my go to color for most bit parts, even wheels
it looks good and its so easy to touch up
Old 02-14-2021, 09:25 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Jake - can you get proper paint/hardener mixed up at a automotive paint supply and put in rattle cans? Rustoleum and the other hardware store paints like it are crap.. As for prep just treat it like any other FG part.
Gary R.
Old 02-15-2021, 01:52 AM
Puny Bird
Mark Henry's Avatar
Don't use rattle can for carbs, any drop of gas will bubble, crinkle basicly ruin the paint. Use a fuel safe paint.
Face it you wiĺ spill some fuel while tuning carbs.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 02-15-2021, 02:04 AM
1988 Carrera
shadowjack1's Avatar
I'm in the your car, do what you want camp. I painted mine white to match the car..
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 02-15-2021, 04:20 AM
GaryR's Avatar
Matched my car at the time, Signal yellow..
Gary R.
Old 02-15-2021, 04:39 AM
khamul02's Avatar
Did you guys use high temp paint?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-15-2021, 07:11 AM
GaryR's Avatar
I used two part enamel (automotive). plenty tough once cured..
Gary R.
Old 02-15-2021, 08:40 AM
1988 Carrera
I used reg. paint. 7 years ago. Still looks good.
88' Carrera
75' Targa gone
72'914 gone
72' 914 gone too
Old 02-15-2021, 09:22 AM
Wer bremst verliert
JohnJL's Avatar
Epiphanes makes great 2-part fiberglass paint. You can get it in many colors including black. It is super strong and impervious to oil, gas and any heat it gets from the motor underneath. Can be brushed, roller or sprayed. Prep is key...your shroud is likely soaked in oil and gas over the years, you need to get that all out and off.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 02-15-2021, 03:31 PM
skinnerd's Avatar
I'd recommend going with amber....but then again I'm biased.
Definitely gives the car that "motorsport" vibe.
It's very easy to repaint these fan shrouds if you choose to go that way..
Definitely use a two part epoxy automotive paint so it lasts.
Color is up to you, but the factory has some pretty good colors: red, green and yellow. I don't consider black a color; it's that the absence of color? Ha
I think any kind of rivet is fine.
I used standard aluminum rivets on my amber shroud.
You can see them above.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 02-15-2021, 07:33 PM
So....good thoughts..and the point about chemicals isn't to be forgotten, anything I do needs to be very chemical resistant. The current PMOs need tuning!
I have cleaned and cleaned, and...I am SURE it's got grease. I will don a charcoal mask and get some acetone going to degrease.
Good point on the JB Weld...I'm using that on my fan before I Cerakote it.
I looked at just buying a new one. The amber FG ones on Pelican (I think) were like $500! So, I think I'll be painting!
Using a mainline automotive paint would be fine, I can spray a sealer/primer first. JB Weld is good to 550F, with is WAY hotter than the shroud will ever see. But what WILL a shroud see? 200?? Maybe 250 or so where it contacts the cam tower? Normal automotive paint is fine for 300 or so, so I think I'd be fine here, especially as the shroud itself is only epoxy resin.
I'm leaning to replicating the green used on the E models (Black on Ts and red on Ss, I think?) Has anyone doe an actual match to some known color? It kind of looks Conda green??
Love the pics, post 'em if you got 'em!
Old 02-15-2021, 08:13 PM
Hubba hubba, very nice shroud!
At $500, I'm going to put that on my "next time" list. Thanks for the rivets advice.
And, what is going on with that transmission?? I don't recognize it. Wild guess....not a 911? A VW bus conversion to a flat 6??? Or the opposite, some super cool race car?
Old 02-15-2021, 08:17 PM
skinnerd's Avatar
Not a 911.....a 914.
Doug
Old 02-15-2021, 08:55 PM
Ahhhh, I wondered about a 914-6. I'm not familiar with the transmission appearance, oddly enough since I've dropped a few with a friend at the race track. Nice looking set up!
Old 02-16-2021, 09:00 PM
Flojo's Avatar
back in 2013 I rattle canned my shroud.
gave it a brutal good clean, some quick sanding with 250 (dry, then wet) and sprayed it two layers.
No issues up to today.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 02-17-2021, 03:12 AM
khamul02's Avatar
Going in the opposite direction.. didn't I see a carbon fiber shroud at some point?
Tom Hutchinson
Old 02-17-2021, 05:22 AM
335 335 is offline
VHT high temp engine paint (Australia) with their metal / fiberglass primer. I filled some gouges with polyester resin and repaired damaged holes with resin and matting. Just reshaped, sanded and primed. I haven't finished final paint yet and I'm a little stuck on the snorkel to oil cooler color. My finished color for the shroud will be gloss black but I haven't yet decided on the snorkel color. It was beige. Engine enamel (according to the can) needs temp to cure for chemical resistance. Let you know when I get it all back together 🤞. I just picked up longer rivets. Not sure what diameter but they are common.
Old 02-18-2021, 11:26 AM
335 335 is offline
Old 02-18-2021, 11:31 AM
