Rear Fog light 80 SC Euro
I’m having some issues with the rear fog light on my 80 SC. The original wires were pretty sorry – so I ran some new wires. The positive is straight forward – as it connects to the post at the base of the bulb. The ground wire though > where does it connect to the lamp assembly?
anyone have a picture of the fog light inside connections??
thanks
kgl
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 11-22-2020, 09:49 AM
creaturecat's Avatar
the ground can be attached to the the "stalk" using a suitable ring type connector.
Old 11-22-2020, 11:06 AM
so > the positive wire runs from battery - to a switch - to the positive screw-down terminal at the light box
the negative wire [-] battery terminal - switch - to a ring connector at the light bracket.
Kim Langley
80 911SC
97 C230
73 BMW 2002Tii
Old 11-23-2020, 10:54 AM
