-   -   Can I use Curil-T on shift fork plate gasket? (http://forums.pelicanparts.com/porsche-911-technical-forum/1077433-can-i-use-curil-t-shift-fork-plate-gasket.html)
markmalin 11-05-2020 01:30 PM
My 85 carrera's transmission is leaking from the lower shift plate (I believe that's what it's called). I'm going to change out the gasket -- I purchased some Curil-T for another project. Can/should I use that on the gasket for the shift plate cover?
Probably a silly question, but I don't think I ever used any kind of sealer on that plate when I did it last - just thought I'd go the extra mile if it's worth it and put some sealer on there as well.
Mark
proporsche 11-05-2020 02:25 PM
yup, good idea;-)just not too much of it...
Ivan
john walker's workshop 11-05-2020 02:33 PM
Goobery sealers on thin paper gaskets often cause the gasket to split and sqeeze out upon tightening. I would use spray coppercoat and let it set up before tightening.
proporsche 11-05-2020 02:59 PM
just wonder what is ..Goobery sealers..? john
Ivan
theiceman 11-05-2020 03:10 PM
i used hylomar that i had left over from another project. holy crap does that stuff seal.
markmalin 11-06-2020 04:55 AM
Did you use the tube, or did you use a spray?
Marc Bixen 11-06-2020 07:56 AM
I like Curil T, sorry John. Hylomar is basically the same thing, non-curing sealent. Hylomar, British, Curil T German.
theiceman 11-06-2020 08:29 AM
i used the tube .. i did not find them the same product at all ( Hylomar and Curil T ) ... but ill defer to the professionals. i used the hylomar blue in a tube..
