Quick Learner
levdeb's Avatar
1972 Targa MFI Pump leaking... rebuild?
Hey all!
Helping a friend with his 1972 Targa. Its got the fuel injection system and the pump just dumps fuel when the key is turned on. Not from the 3 hose connections, but from just under the electrical plug connection.
Is it possible to rebuild these? I see they are upwards of $800 plus on our host site here.
The car is already not stock, so if there is an alternative method to replace this (standard fuel pump and regulator??), that would be fine too.
Any advice would be appreciated! Thank you!
Old 11-04-2020, 11:16 AM
Rescuer of old cars
Arne2's Avatar
Can't post links to other Porsche suppliers sites here, but the Zims MFI replacement kit works well. Google it.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 11-04-2020, 11:21 AM
Quick Learner
levdeb's Avatar
That is exactly what we need. Thanks again!!!
Old 11-04-2020, 11:22 AM
I would search for fuel pump repair or rebuild. Several posts on the subject showing seal sizes and sources. I have not seen anyone selling a complete repair kit. Rob
Old 11-04-2020, 04:20 PM
Search under jeff higgins for his thread about leak fixing.
206 637 4071
Old 11-04-2020, 06:17 PM
Quick Learner
levdeb's Avatar
Thanks all! I will check out Higgins thread while waiting for this Zims to arrive!
Old 11-05-2020, 05:39 AM
Rescuer of old cars
Arne2's Avatar
I repaired the leak in my original pump, but it started leaking again after a couple of months. The Sims replacement has been working perfectly for well over a year.
2018 718 Cayman 2.0
Old 11-09-2020, 01:43 PM
(man/dude)
Jonny042's Avatar
I know you've found and ordered a solution, but for other's reference, If you don't mind plumbing and mounting an "inline" style pump, a Bosch 69458 ('84-89 Carrera) works perfectly:
Post #453 of my build thread:
Project Heavy Metal - an all steel classic, remastered
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 11-09-2020, 03:52 PM
Quick Learner
levdeb's Avatar
If I could just get this new fuel line that came with the kit to fit on the much larger fuel tank line end....! About 2 inches of space...! But it'll be worth it.
Old 11-09-2020, 04:02 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
yea, those pumps are ridiculously expensive. I think they produce more PSI for the MFI then a regular pump.
73 e
Old 11-09-2020, 06:04 PM
