headlight adjusting screws help!
I took my headlight ring to get powder coated black and the tech cut off the headlight adjusting screws.
I tried to order them without the headlight bezel. but I can't seem to do that.
does anyone know where or what size the screws are so I can just go to ace hardware or a bolt and screw place to buy just the screws?
thanks in advance>
06 E55 600HP
08 Clk63 black series 590HP
81 SC targa 3.0
91 E34 M5
Old 10-30-2020, 05:27 AM
What headlight assembly do you have? Stock sugar scoops, or H4? Can you post a pic of what you have? I have a full sugar scoop assembly on a shelf in the garage. If that is what you have, I could measure any of the necessary screws when I get home.
Old 10-30-2020, 06:28 AM
creaturecat's Avatar
H4? difficult to source.
got mine thru a wtb ad on Pelican. 40 bucks. the long screw is impossible to source (new), far as i could tell.
Old 10-30-2020, 09:09 AM
AutoBahned
RWebb's Avatar
the "tech" owes you a complete new assembly
Old 10-30-2020, 11:06 AM
famoroso's Avatar
They are available from Belmetric.
MSOVAL4X60SS
https://www.belmetric.com/4mm-oval-head-screws-c-563_900_1484_1272/msoval4x60ss-oval-phillips-stainless-p-11682.html
I used M4x0.7 SS nylock nuts as retainers.See below for the measurements (expressed in the number of 360 degree "turns") for the tabs that the screws engage.
Assuming the assembly was original, you wouldn't have been able to remove the original screws without damaging the threads anyway, as they use a crimped steel ring (i.e. not a nut) to retain the screw. Crimped rings clearly visible in the below pics. So I don't think the tech owes you anything.
Quoting from this thread... How to remove headlight adjusting screws H4 ...
Originally Posted by famoroso View Post
Hold the crimped steel ring with a pair of needle nose pliers as you spin the screw off. Alas, this destroys the threads on the screws. Purchase replacement stainless steel screws and matching nylock nuts from BelMetric (I can dig up the sizes if you need 'em) for reassembly.
Don't tighten the nylocks down completely against the screw or you'll lose the ability to turn the adjuster once everything is reassembled. Snug it down close enough to retain the adjuster screw, bit still allow it to rotate freely. Be careful tightening the screw as holding the assembly while doing so is awkward and there's a lot of screwing to be done... It's easy to slip and hit the painted side of the ring with the screwdriver. Power screwdriver works well in this application, but may increase the chance of slipping / damage.
I didn't take after pics, but...
I had my H4 rings done. Came out GREAT...
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 10-31-2020, 03:58 AM
that will work with the L type connector.
the more usual configuration requires a 120mm screw.
Old 10-31-2020, 11:49 AM
If you need the 120mm screws,I think those are not manufactured anymore. that is why they started using the 60mm screws with the L type connector.
That L type connector is very easy to adapt to the headlight housing and is available from different vendors. I just bought for $16.00 a set of headlight assembly hardware kit ( the kit does 2 headlights ) that has those L connectors.
Old 11-01-2020, 08:45 PM
Dang it sorry, i have H4 headlight setup on my 81. thanks a bunch everyone!!
06 E55 600HP
81 SC targa 3.0
91 E34 M5
Old 11-13-2020, 04:27 AM
I agree with you but his excuse was he couldn't get them off. So he cut them
06 E55 600HP
81 SC targa 3.0
91 E34 M5
Old 11-13-2020, 04:29 AM
H4 Sorry!
06 E55 600HP
81 SC targa 3.0
91 E34 M5
TY sir!
06 E55 600HP
81 SC targa 3.0
91 E34 M5
Old 11-13-2020, 04:30 AM
