keying key blank to bonnet / trunk lock and glove box lock?
Hi everyone. I tried a search for this but didn't find much.
I don't know the entire history of my car but at one time a new ignition was put in and I only have a key for it and not the doors, glove box and trunk / bonnet lock as I have a targa. I don't care about the doors as I would probably not lock my car in most / all situations given the targa top is much more expensive to repair than anything I may have in the car. But I would like to have a working key for the glove box and trunk lock, assuming they are the originals. Is it possible to have a locksmith make one of these (basically a valet key) for these two locks? Has anyone done this before? TIA, Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs Last edited by sbrown.nw; 11-10-2020 at 01:11 PM.. |
Scott - might be easier/more straightforward to have a locksmith re-pin the tumblers in your door /hood / glove box locks to match the pins in your ignition lock. While I hear you on not locking doors, around here thieves like to pop door handles for open doors and then use an open door as an excuse to rummage through (and be destructive to) a car's interior (i.e. crowbar the glove box open BEFORE even checking to see if it's locked, crowbar out radio/etc. I'd rather have my car pass the locked door test than not.
My car still has all original locks. The black key will work on the doors, ignition, the trunk lock and the glove box lock. And I use all of them. The red key only works on the doors and ignition.
You should be able to go to a dealer with your title and have them cut you a new key, or order it to fit any original lock. That would get you in everything but the ignition. I think it is possible to re-key the ignition lock if it is removed.
Glen 44 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
There's a tutorial on Pelican How Tos. It takes a little time, and the tumblers can be stubborn, but it can be done. I just finished my door locks to match ignition.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
I agree with two of the posters.
Our '86 Targa has black key for all locations except for the rear seat delete. For the RSD, I had a shop replace the wafers in the two locks. Your black key should work as described. Best, Gerry Last edited by 86 911 Targa; 11-11-2020 at 12:33 PM.. |
It is not difficult to remove the tumblers from the doors, glove box and Frunk lock. I had a local locksmith rekey these to match my ignition key. Not terribly expensive.
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1973.5 911T Targa - "Smokey" 2003 BMW Z4 3.0i 2009 MB C300 |
This old post shows the differences between the regular and Valet key. The Cuts are the same. Note the grooves in the two keys.
Any links how to do this?
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs |
Googling "remove tumbler from 911 door handle," I found this tech article https://www.pelicanparts.com/techarticles/mult_lock_rekey/mult_lock_rekey.htm -- looks to be pretty straightforward
The ignition lock is no harder than the doors to rekey. This is the path I took with my 84 after I got it. it came with the original keys which worked everything but the ignition. It also had Porsche supplied keys for the replacement ignition. I chose to rekey the ignition, as that way the original key code for the car would still be correct, plus that way I only had to rekey one cylinder instead of four. I also created a key for the missing alarm key. You can see the thread here, and the same process could be used to create a key for your missing door, GB and trunk key if necessary.
What is so difficult in removing it from the car? I agree there are a couple shear head bolts that need to be removed, but a Dremel with cutoff wheel will slot the heads in the matter of a few seconds then you just use a flat blade screwdriver and turn them out.
In the Pelican Parts article, they show a "re-keying kit", they show it in this pic :
![]() I have searched everywhere for this kit but I could not find it, do I need this kit to re-key my door key cylinders to match my ignition key?
-1987 Carrera Coupe, -1977 911S with a Euro 3.2, single GTX3584 turbo, 930 4 speed trans, Microsquirt engine management. |
To my way of thinking, At $40 each it is not a skill I need to learn.
Thread Tools | |
Rate This Thread | |
