Where can I get a 993 exhaust flange?
I am working on a project and looking to for two exhaust flanges for the 993 Bischoff three hole exhaust flange
I saw a site a while back that sold them, but not sure what that site was. I have slept since then. It matches these gaskets. ![]() Thanks, John
John- 78 Slick Top 930 "Illegitimi non carborundum" |
cycling has-been
Bring the gasket to a muffler shop. They can trace the outline and cut you new flanges on a water-jet.
FWIW, I had this done but found out later they subcontracted the water-jet out to a local machine shop....maybe skip the middle man? Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Thanks Bill.
Not easy to find. Save for custom laser or water jet fabricating to shape, I believe the crossover exhaust pipe connection on SC and Carrera heat exchangers use these gaskets. Locate some junk heat exchangers and cannibalize?
Sherwood |
It's a 914 ...
mb911 on the forum is an exhaust fabricator and may be able to help you
Thanks all. Anyone have any scrap pipe sitting around with these ends on it? You know where I am going with this right? Pm me.
I haven't used them personally, but check these guys out if you don't have a local option: https://sendcutsend.com/
I can get them in stainless
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Thanks Ben. I will PM you.
