headlight adjusting screws help!
I took my headlight ring to get powder coated black and the tech cut off the headlight adjusting screws.
I tried to order them without the headlight bezel. but I can't seem to do that. does anyone know where or what size the screws are so I can just go to ace hardware or a bolt and screw place to buy just the screws? thanks in advance>
06 E55 600HP 08 Clk63 black series 590HP 81 SC targa 3.0 91 E34 M5 |
What headlight assembly do you have? Stock sugar scoops, or H4? Can you post a pic of what you have? I have a full sugar scoop assembly on a shelf in the garage. If that is what you have, I could measure any of the necessary screws when I get home.
H4? difficult to source.
got mine thru a wtb ad on Pelican. 40 bucks. the long screw is impossible to source (new), far as i could tell. |
AutoBahned
the "tech" owes you a complete new assembly
They are available from Belmetric.
MSOVAL4X60SS https://www.belmetric.com/4mm-oval-head-screws-c-563_900_1484_1272/msoval4x60ss-oval-phillips-stainless-p-11682.html I used M4x0.7 SS nylock nuts as retainers.See below for the measurements (expressed in the number of 360 degree "turns") for the tabs that the screws engage. Assuming the assembly was original, you wouldn't have been able to remove the original screws without damaging the threads anyway, as they use a crimped steel ring (i.e. not a nut) to retain the screw. Crimped rings clearly visible in the below pics. So I don't think the tech owes you anything. Quoting from this thread... How to remove headlight adjusting screws H4 ... Quote:
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" Last edited by famoroso; 10-31-2020 at 04:18 AM.. |
that will work with the L type connector.
the more usual configuration requires a 120mm screw. |
If you need the 120mm screws,I think those are not manufactured anymore. that is why they started using the 60mm screws with the L type connector.
That L type connector is very easy to adapt to the headlight housing and is available from different vendors. I just bought for $16.00 a set of headlight assembly hardware kit ( the kit does 2 headlights ) that has those L connectors. ![]() ![]()
Dang it sorry, i have H4 headlight setup on my 81. thanks a bunch everyone!!
I agree with you but his excuse was he couldn't get them off. So he cut them
H4 Sorry!
