1967 Restoration. Need engine advice!
So I randomly came across a rare matching numbers 1967 911 that the COA says is Black, which is my dream. So with the help of a friend and his shop, I decided to take the plunge into restoring the car to its factory color. But pertaining to the motor, I need your guys advice. I cant decide which direction to go....
So here are the facts, I sold a 1972 911 with a MFI 2.7 motor that put out 206 rwhp. Car was a blast to drive. So i had that experience with a longstroke 2.7 motor. Now with this build, I want to do something different. Have always dreamed of a wicked 2.5 short stroke that revs to 8k. For me, I already have a 997.2 RS and a 964, so my priority is more visceral feel and experience rather than pure speed. I have the matching case that needs some machine work, but I also have a spare 67 case that I could hot rod. What i am worried about is building a motor that is not balanced with the chassis, or is just too much power for it, where I cant have fun carving canyons because I am feathering the throttle all the time. There is something to be said about having a blast going WOT with a 2.4 through the canyons. So much fun. Car will have updated suspension with sway bars and upgraded brakes, but nothing too crazy. Just a nice strong street setup. 21/26 torsion bars. Tires will be 185 Avons all around with steelies. Here are the ideas of possible engine ideas - 2.5 Short Stroke (220-250 hp) Shelve matching numbers case, and use spare case to build the hotrod motor. I have been told its a great motor, but lacks a lot of grunt midrange. Do short gearing 2-4 and lsd to maximize the power band. - 2.8 Short Stroke (280-300hp) Have been told the price to build a 2.8 over a 2.5 is negligible, and with the 2.8 you get the midrange torque while having it scream up top. Henry from Supertec refers to it as the ultimate Porsche motor. But I am concerned its too much for the chassis, and the 185 AVON's all around. Do short gearing 2-4 and lsd to maximize the power band. But also not sure if 901 transmission can handle power reliably. - 2.45 Long Stroke - Shelve matching case, use spare case to use a longstroke crank and rods, and built a nice fun street motor that revs to 7000. Simple and fun. Do short gearing 2-4 and lsd to maximize the power band. - 2.2 Short stroke - Use matching numbers case to build a nice short stroke. Take a deep breath from the monster motor build ideas. Do short gearing 2-4 and lsd to maximize the power band. Something kind of cool about a nice clean SWB hot rod running around with a matching numbers case
2011 GT3 RS 1991 Carrera C2 1972 911T |
Anyone? lol : )
seems the limiting factor's going to be the 901 transmission, see 901 vs 915 gearbox & a short stroke 3.2
Perhaps shoot for a power to weight ratio similar to the original 911r? |
The more power the better.
You said it yourself you always dreamed of a 2.5 short stroke.... It is one of the options you list...
Assuming the 901 will handle it, you can play with gearing and weight saving/adding measures to balance the car to your liking.
Now: 2013 Cayenne GTS Ex: 1999 C2, 2004 Cayenne Turbo, 2002 C4S, 1999 BMW M Z3 Coupe, 2013 Audi RS5 |
I had Ed Mayo build a 2.3 liter for my 67 911S hotrod. Twin-plugged with 2.2 heads. Chassis weighed 2100lbs wet and power from engine was right at 210 HP. Plenty quick enough and every run through the gears lasted long enough to thoroughly enjoy.
901 box is fine for this as long as you don’t want to lay rubber in first. The 911R used a 901 box when it ran 96 hours at Monza in early 1968 averaging 130 MPH including time spent replacing front suspension. I can supply build details if requested. |
With power and the weakness of low gear, find a 4 speed so all the power stays on the main shaft
Bruce |
Yes, light car doesn’t need 1st unless you want to drive up incline from a stop.
I vote 2.2 or 2.5. Either would be a blast in this car... especially since you have other, more modern, go-fast cars when needed.
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
Yea, that is what my gut is telling me. I cant imagine a closed geared 2.5ss that revs to 8k being boring. It has to be badass
Cable for internet is down so I can’t send info now. I sold my car on BAT about four years ago. Search for “Modified 1967 Porsche 911S” for some info. I also have a YouTube in-car video that provides an idea of what it’s like to drive a hot 2.3 in a lightweight SWB.
The 2.3 with Webers was originally used in 911STs. With S-cams (GE-40) torque peaks at 6600 RPM and HP is about 210. GE-60 cams will produce about 230 HP at 7000 RPM and GE-80 cams allow even more with a 8000 RPM redline. Contact me via email provided on my website “PerformanceOriented.com” Last edited by 1QuickS; 02-22-2021 at 08:55 AM.. |
