carwash's Avatar
What Tins? SC3.0 in a 68 912 chassis
Doing this 3.0 swap into this 912. My tins aren’t in great shape and I’ve also deleted all hvac content on the motor. Also plan to run a front oil cooler and delete the onboard motor one.
What replacement engine tins should I get? Or what set should I start with to modify etc ?
Old 11-08-2020, 10:32 AM
carrera30's Avatar
Until I actually found these screws, I went to a hardware store, bought a shorter screw, bought a threaded union & a threaded stud w/no head, married them together & it worked well!!!^^^
I guess a 1st question is, what's the 3.0 engine out of. Maybe give us the engine #.
Sent from my SM-A115A using Tapatalk
Mill Beatty
Coordinator for the 911 Carrera 3.0 North American registry site>
Old 11-08-2020, 12:40 PM
carwash's Avatar
Engine is out of an 83 SC. Not sure of numbers. Not near it right now.
Old 11-08-2020, 02:33 PM
I would rather be driving
jpnovak's Avatar
stock tins work fine as long as you have moved the engine mounts.
I would not delete the engine mount oil cooler unless you really have everything planned out and have a good adapter plate.
Old 11-08-2020, 02:53 PM
carwash's Avatar
Yes, the chassis was converted to 6 cylinder well before I got it, so the orig mounts are gone and flat 6 mounts installed.
I just did some research and realize I can use both the engine mounted cooler as well as a front mount, so I will retain it for sure. It seems tougher to remove and bypass it.
1968 912 - widebody - 3.2 - 915 - endless build
1980 911 - targa - barnfind nightmare - gone
1985 911 - targa - barnfind nightmare - gone
2017 991 - C4S - summer daily - for sale
IG - therealcarwash
Old 11-08-2020, 03:02 PM
SWS911's Avatar
The pass side side tin on a 3.2 Carrera does not have an air socket and I know '74 and earlier rear tins don't have any "holes". Your SC engine should have the drivers side side tin with no air socket and a block off plate just to the right of the fan. I ended up getting a metal block off for the drivers side from Patrick Motorsports. A little pricey but nice!
Old 11-17-2020, 07:10 PM
I’m doing the exact same thing as you right now. Also with an 83 3.0.
Rennspeed sells fiberglass versions of the tins. Good to save as much weight as possible on the rear.
1975 911 3.4 outlaw/hotrod? lsd
1988 535i
1987 535is
1973 bronco ranger
Old 11-17-2020, 08:11 PM
carwash's Avatar
Thanks for the information. This is just what i was looking for.
Old 11-18-2020, 03:51 AM
carwash's Avatar
I can’t imagine the metal ones weighing very much more than the fiberglass ones. I will look into that kit though. Wanted metal so that I could powder coat them.
Old 11-18-2020, 03:53 AM
