cold start problem not resolved
1987 Carrera
With the engine totally cold, started the car. The engine starts right away but in a missing fashion for about 2 seconds and then goes to 1200 RPM...And does its routine going down to 900 as programmed. The funny thing is that if I start it again 5 or 6 hours later, it starts properly, no hesitation I did remove the valve cover on the upper left side, there were a few smears of oil but the roker shafts seem to be at in their place, changed the gasket and secured the plugs wires with RSR hold downs. Just installed a new fuel pump so it is not the check valve Any thoughts?? |
Following
David you post is like guessing game.Not solved..what did you do to try to solve it , that would help to mention here,how about that?.... so people can actually follow....
Ivan |
problem with cold start
I did what was described and awaiting new wormer spark plugs non resistive to replace the current ones.
Other then that, I do not have any ideas of what to do next to resolve the cold start "missing" symptom... It is not a big deal because it only lasts for 2-3 seconds...but it annoys me. |
My cars did exactly what you described until the Idle Control Valve completely failed. Once replaced - problem solved. My guess is that your ICV is failing.
From one PeterM to another Peter M! ICV controls bypass air at all temperatures. |
I will use that information in my own tread on idle issues |
Please test things instead of replacing them. A fuel pressure meter hooked to the fuel rail would have saved the cost of a fuel pump.
Things to check at this point. - ICV - Idle position switch - Cylinder head temp sensor And doing the idle speed setting procedure would be good about now. |
Reference and speed sensors could be starting to fail or covered with oil/dirt.
CHT sensor is a good one. I had changed mine a few years ago when it failed as well, so that's why I didn't bring it up.
It's not a hard fix - just a little tricky getting the socket on the sensor. |
Subscribed. Same symptoms except mine chokes and coughs for about 15 seconds before it revs up and down. Then like yours its fine. Even after sitting for hours.
I took it in for this. They did a smoke test on the vacuum line and replaced several hoses. Didn’t fix it.... |
Oh, forgot to mention that I get a nice bit of white smoke now that accompanies the choking. This is new too.
| All times are GMT -8. The time now is 08:55 AM. |
