1983 911sc wont start
Hi-
I'm hoping I can get some advice on my SC. Went out to drive this weekend the the engine would turnover, but not spark. While I've only had the car for 7-8 months, no known issues here (once this summer it started on a second attempt, but otherwise has always fired the first time). Ran perfectly during the ~100 miles I put on it last weekend. I tested the battery and the meter read 12.6, so I think the battery is ok and I'm working down the list to check next. Based on other threads I've read, it's likely a spark or fuel issue. I'm a total novice here, but would appreciate some guidance on next steps in investigating the cause or at least ruling out what it isn't. If it's simple as spark plugs (or at least, relatively simple as these things come) it would probably be something I can address, otherwise I'll need another set of hands - just wanted to do all the checking before I get to that point. Thanks. |
Check and reseat red fuel pump relay as well as fuel pump fuse ( both located in frunk fuse box )
Bill |
Since the engine is cranking the battery is OK. First step is to check for a spark. Pull off a plug lead, connect to a spare plug, rest plug on engine metal (to get an earth), get someone to crank the motor and look for spark. If you have a good spark then need to look at fuel system: could be fuel pump relay as suggested above.
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
Thanks both for the feedback. I'm going to check later this week on both items - appreciate it.
Porsche Addict
Spark.
Compression. Fuel.
Lawrence - 1986 911 Carrera Coupe Grand Prix White 1959 Land Rover Series II 1962 Volkswagen Sedan Ragtop 1959 Porsche 356A Coupe 1971 Porsche 911T coupe |
Yup, my car started for a split second and died. Fuel pump fuse blew.
JUAN '80SC Targa |
